Will the headlight automatically turned off - NC?
ddent
Postby ddent » Thu Aug 06, 2009 11:07 am
Hi,
Parking my MX5 at the airport but not sure I turned off the headlight. The battery has recently flatted out so a bit apprehensive now.
Will the headlight automatically turned off when we turned the engine off - for NC?
JBT
Postby JBT » Thu Aug 06, 2009 11:13 am
No....but there is a beeper that activates if the door is opened and the lights are on. If you can't/couldn't hear the beep...
ddent
Postby ddent » Thu Aug 06, 2009 11:48 am
Not sure. The beep will normally activated when I left key in the iginition.
Hope I did not forget to turn it off... :frown:
Thanks
JBT
Postby JBT » Thu Aug 06, 2009 12:07 pm
The "lights on" warning beep only comes on with the key removed from the ignition and the driver's door open.
IB1ZA
Postby IB1ZA » Fri Aug 07, 2009 2:51 pm
There is a kit available from Mazda which will
a) turn the lights on when it is dark
b) turn the lights off when there is enough light
c) set a timer for 30 seconds when you turn the car off to keep the lights on and then turn off after 30seconds.
It is about $100 or so. easy to install to
http://www.highclass.net.au/
TieNN89
Postby TieNN89 » Thu Sep 24, 2009 8:36 pm
Its called Auto Headlights IB1ZA ;)
