Nitrous
philz
Wheel guru
NOS
Postby philz » Sun Sep 20, 2009 8:25 pm
Nitrous
Nitrous
Postby Jeo » Sun Sep 20, 2009 8:55 pm
mx52nv used to run nitrous, paging Les...
What's it for? I'm really hoping some kind of racing and not just "need two of the big ones" style theory.
AJ
Nitrous
Postby AJ » Sun Sep 20, 2009 9:19 pm
nitrous on the track???.........are you on CRACK?? :? .............Nos is for a drag strip with a 5 second burst & an engine designed to burn it :roll:
& if you don't like WOT, you certainly WON'T like the kick in the arse you get from Nos :lol:
XMX5 Rogues
StanTheMan
Nitrous
Postby StanTheMan » Sun Sep 20, 2009 9:55 pm
What's WOT ?
I'm guessing.....but in the long term, its going to cost you more to keep enough nitrous bottles Than just getting a decent FI set up.
AJ
Nitrous
Postby AJ » Sun Sep 20, 2009 9:57 pm
Wide Open Throttle Stan.......lol
which is what you're supposed to be using when you hit the Nitrous button :lol:
XMX5 Rogues
StanTheMan
Nitrous
Postby StanTheMan » Sun Sep 20, 2009 9:58 pm
Cheers AJ :mrgreen:
mx52nv
Purple Porsche Eater
Nitrous
Postby mx52nv » Mon Sep 21, 2009 3:35 am
Hi Mazfan,
Mazfan wrote:Hi guys,
I have had my mx5 for about a month now, great car and I'm enjoying it very much.
It is still stock. I have thought of S/C or turbo but its expensive to do,
Nitrous is the cheapest and I'm just wondering if its a good idea.
It is not the cheapest in the long run and whether or not it is a good idea depends on application.
Mazfan wrote:are any of you running nitrous or had experience with it?
Yes, I used to and yes, I have experience with it.
Mazfan wrote:What kind of HP can you run safely on stock engine? I have the VVT engine with higher compression.(2001)
The SVT models had a little over 10 to 1 static compression ratio I think. I am not liking the numbers already. Maybe a 50hp shot max?
Mazfan wrote:I want to do track days in the future, so I'm thinking that nitrous will be the best and least expensive mod to
make up time on the higher HP cars on the straights. Also I don't like the idea of WOT, don't want to the back coming out
in town. What is the best setup? Can you fit it yourself, does the kit include everything, do you need to buy ECU?
As someone who has experience with NOS setups in MX5s, may I humbly suggest that using it on the race track is not the best idea. As AJ has already mentioned, NOS should only be activated at Wide Open Throttle (W.O.T.) usually to ensure that there is sufficient fuel.
Best setup depends on application. For most "street class" 4 cylinder E.F.I. cars, I would use a 'wet' multi-point kit which uses four (or more) nozzles for both fuel and NOS. As for fitting it yourself, unless you have done one before, do not try to install the kit I refer to above. A kit will include all mechanical parts, lines, nozzles and bottle. Usually no E.C.U. is included from most NOS manufacturers but things may have changed since I last heard.
I took NOS off my car because I could not control the car when the power hit. It would just automatically change lanes on me and this was with Falken 205 wide R-specs.
I must also state that NOS is not legal in any state under Federal Transport laws and this would also negate any insurance that you may have.
I humbly suggest adding your location to your profile and getting in contact with your local MX5 club and start going to track days. Suspension, tyres and track time are your best investments.
Les
CT
Nitrous
Postby CT » Mon Sep 21, 2009 9:15 am
NOS is illegal in ALL forms of circuit racing. NOS is for Fast and the Furious movies and 400m - nothing else.
Boyracer
MX-5 Encyclopedia
Nitrous
Postby Boyracer » Mon Sep 21, 2009 9:32 am
Good for when you get teeth pulled out as well.... :lol:
AJ
Nitrous
Postby AJ » Mon Sep 21, 2009 11:47 am
Boyracer wrote:Good for when you get teeth pulled out as well.... :lol:
works a treat on hangovers too :wink: .......misspent youth in the company of Nurses on nights out :oops: :lol:
XMX5 Rogues
Nitrous
Postby bruce » Mon Sep 21, 2009 12:47 pm
Don't try sniffing the NOS out of the blue bottles as they add egg-gas to it to stop everyone having a laugh-fest.
Fuzzlet
Nitrous
Postby Fuzzlet » Mon Sep 21, 2009 7:29 pm
Yea adding NOS for 'down the straight speed' sounds like a dumb idea, even to me (and trust me, I have plenty of em when it comes to cars haha)
Nos will cost u a lot to run it all the time, even for the drags. Spend the money on a decent turbo setup and u can have the power at the strip/circuit/street, hell even doing burnouts in ur driveway if thats what ur into
StanTheMan
Nitrous
Postby StanTheMan » Mon Sep 21, 2009 8:38 pm
Fuzzlet wrote:..... if thats what ur into
:lol: :lol: :lol:
Old Dude
Nitrous
Postby Old Dude » Mon Sep 21, 2009 8:46 pm
:lol: :lol: :mrgreen:
MX 5 2001 Grace Green
NB8B
Boags
Nitrous
Postby Boags » Tue Sep 22, 2009 9:34 am
:shock:
