Nitrous
Nitrous
Hi guys ,
I have had my mx5 for about a month now, great car and I'm enjoying it very much.
It is still stock. I have thought of S/C or turbo but its expensive to do,
Nitrous is the cheapest and I'm just wondering if its a good idea.
are any of you running nitrous or had experience with it?
What kind of HP can you run safely on stock engine? I have the VVT engine with higher compression.(2001)
Nitrous
I want to do track days in the future, so I'm thinking that nitrous will be the best and least expensive mod to
make up time on the higher HP cars on the straights. Also I don't like the idea of WOT, don't want to the back coming out
in town. What is the best setup? Can you fit it yourself, does the kit include everything, do you need to buy ECU?
- AJ
Nitrous
nitrous on the track???.........are you on CRACK?? .............Nos is for a drag strip with a 5 second burst & an engine designed to burn it
& if you don't like WOT, you certainly WON'T like the kick in the arse you get from Nos
XMX5 Rogues
- StanTheMan
Nitrous
What's WOT ?
I'm guessing.....but in the long term, its going to cost you more to keep enough nitrous bottles Than just getting a decent FI set up.
- StanTheMan
- mx52nv
- Purple Porsche Eater
- Vehicle: Non MX-5
Nitrous
Hi Mazfan,
Best setup depends on application. For most "street class" 4 cylinder E.F.I. cars, I would use a 'wet' multi-point kit which uses four (or more) nozzles for both fuel and NOS. As for fitting it yourself, unless you have done one before, do not try to install the kit I refer to above. A kit will include all mechanical parts, lines, nozzles and bottle. Usually no E.C.U. is included from most NOS manufacturers but things may have changed since I last heard.
I took NOS off my car because I could not control the car when the power hit. It would just automatically change lanes on me and this was with Falken 205 wide R-specs.
I must also state that NOS is not legal in any state under Federal Transport laws and this would also negate any insurance that you may have.
I humbly suggest adding your location to your profile and getting in contact with your local MX5 club and start going to track days. Suspension, tyres and track time are your best investments.
Les
It is not the cheapest in the long run and whether or not it is a good idea depends on application.Mazfan wrote:Hi guys,
Yes, I used to and yes, I have experience with it.Mazfan wrote:are any of you running nitrous or had experience with it?
The SVT models had a little over 10 to 1 static compression ratio I think. I am not liking the numbers already. Maybe a 50hp shot max?Mazfan wrote:What kind of HP can you run safely on stock engine? I have the VVT engine with higher compression.(2001)
As someone who has experience with NOS setups in MX5s, may I humbly suggest that using it on the race track is not the best idea. As AJ has already mentioned, NOS should only be activated at Wide Open Throttle (W.O.T.) usually to ensure that there is sufficient fuel.Mazfan wrote:I want to do track days in the future, so I'm thinking that nitrous will be the best and least expensive mod to
Les
- AJ
Nitrous
Boyracer wrote:Good for when you get teeth pulled out as well....
works a treat on hangovers too .......misspent youth in the company of Nurses on nights out
XMX5 Rogues
- Fuzzlet
Nitrous
Yea adding NOS for 'down the straight speed' sounds like a dumb idea, even to me (and trust me, I have plenty of em when it comes to cars haha)
Nos will cost u a lot to run it all the time, even for the drags. Spend the money on a decent turbo setup and u can have the power at the strip/circuit/street, hell even doing burnouts in ur driveway if thats what ur into
Users browsing this forum: No registered users and 222 guests
