Does anyone know the difference between the BP05 heads. Some have a -7-1 and -9-1 on the end. Also are there different heads with more numbers?
So far I have found BP05-7-1 and BP05-9-1 heads, any others? Different?
Cheers.
BP05-?-? head differences
- Vehicle: Non MX-5
project.r.racing wrote:Does anyone know the difference between the BP05 heads. Some have a -7-1 and -9-1 on the end. Also are there different heads with more numbers?
Have seen BP05-11-1 & BP05-7-2 off MX5s. Have also seen BP05-4-1k off an Astina. Don't know what differences the numbers designate.
I had a BP05-6.2 and a BP07 of similar mileage side by side. Mostly I felt the BP07 was better made.
Regarding the BP07:
- as far as I could tell the BP07 used a finer casting sand
- casting appeared to be better done (fewer dags in the ports, but still with some big gaps on the inlet port splitters)
- the metal was harder all over
- it was more accurately machined
Regarding the BP05
- the machining was very bad. Maybe mine was just done on a bad hair day, its manifold stud holes were about 4mm out on both inlet and exhaust)
- BP05 valves had a fatter, squarer profile on the rims and were a better shape for cutting.
- BP05 cams and lifters were in better shape
There were somne trivial diffs in the cosmetic external casting details. Otherwise all the port shapes, valve sizes, springs, seats, etc were pretty much identical. 31 out of 32 valve springs failed to meet minimum OEM specs.
In the end I used the BP07 head because of hardness issues but fitted the BP05 valves, lifters and cams.
It's worth noting that we tested 5 or 6 heads for hardness and all but one failed in the gasket surface area around the exhaust ports.
Regarding the BP07:
Regarding the BP05
manga_blue wrote:I had a BP05-6.2 and a BP07 of similar mileage side by side.
manga, do you know what the BP07 was out of?
Both heads were from NA8s. The BP05 was a 5/95 build, not sure but I think the BP07 was a slightly earlier car.
ta - hadn't heard of the 07!
I probably wouldn't pay much attention to it. The numbers may just refer to castings. I don't know if Mazda used it for casting batch numbers, or different foundry lines within Mazda or even different supplying foundries. Almost anything in the casting can be cleaned up so long as there's enough the metal and it hasn't gone soft.
also seen a bp05-8-2
Re: BP05-?-? head differences
Also a BP05-4-2 head on a '93 NA8.
Please can you remember what year MX did this come from?93_Clubman wrote:also seen a bp05-8-2
mazdatenfive wrote:Please can you remember what year MX did this come from?93_Clubman wrote:also seen a bp05-8-2
MX5 BP05 heads were used on the NA8 from Sep 1993 to 1997, but I can't remember which specific year between those dates that BP05-8-2 belonged to. Indeed, I may not have known any more than it was an NA8. Of course, the BP05 head was used on other models by Mazda & other manufacturers, & even the BP05-8-2 head seems to have done the rounds:
http://www.google.com.au/search?q=%22BP ... rt=10&sa=N
Users browsing this forum: No registered users and 109 guests
