Rear brake caliper is beached as bro!!!
okay so today i attempted to change my rear brake pads, after changing my fronts, and putting slotted rotors in the front too. everything went sweet till i tried to push my rear left brake caliper back in so i could fit the new pads, and well it really didn't wanna move at all, i actually broke the tool i had trying to push the caliper back in. I also tried to loosen the bleeding nipple, and then push ithe caliper back in with a c clamp with no success. Does anyone have any suggestions as to what may be wrong, or how i could get the caliper back in???
- de Bounce
Do a search on how to install rear pads on a Miata or MX5
Heaps of how too's with pictures
Try here
You need to wind the pistons back with the 4 or 6mm allen key.
Try here
- broady
want a chup brew?
人馬一体 NA8
6/5/2010
i only eat plankton...
ummm thanks de Bounce... you de Shizzle, always helps if you read the instructions haha
can you damage it if you try to foce it back without winding the hex screw at the back??
every ounce counts
- Garry
Yeap
Users browsing this forum: No registered users and 197 guests
