Hi,
Just purchased some clear indicators, and was wondering what the trick was with removing the standard ones?
Any help greatly appreciated.
Thanks
Fitting clear indicators
- sliq
turboalfa wrote:Hi,
Thanks
with a phillips head screw driver?
have a look on the sides of the indicator ( i cant remember if its on the left or right) there will be a clip, all you need is a philips head as sliq said, should come right out.
Or .. do you mean the ones on the 1/4 panel?
Use something blunt, an old plastic video card etc might do, or a blunt butter knife (so you dont scratch the paint), then i think the tab is on the side facing the rear of the car, slide your tool under the rear side of the 1/4 panel indicator and it should release the tab that holds them in.
If you look at your replacement items you'll see the tab I mean.
Thanks I got it.
Okibi your description should help any other guys that have simliar problems.
I did a search originally put couldn't find anything.
Thanks for the replies. They look great.
- bensale
I find a flat blade screw driver and a rag/cloth of some sort so you don't scratch the car does the trick.
www.othersideproductions.com
- Alex
I found the best way of removing them without any risk of damaging the paint is to open the door halfway so you can see the tab then just use something long to press on the tab from the inside (push it towards the front of the car), I used a ruler to do mine.
the signalling lights side mounted on the front mudguards are commonly known as side repeaters.
- broady
Mr Morlock wrote:the signalling lights side mounted on the front mudguards are commonly known as side repeaters.
Thanks for the hot tip sir
人馬一体 NA8
6/5/2010
