Was a great day and it was great to catch up with you all.
My car actually made 183RWKw, and I'm very happy with this result.
Like Rikko, I could have turned up the boost a bit and the rev limiter, but I wanted to see what it did with the same settings I normally run on the street, which are 14-15lbs of boost and the normal 7200 RPM rev limiter.
Please correct me if I'm wrong, but Rikko's initial runs were reading around 178RWKw, and it was only then he upped the boost and revs to try and beat my car.
I'm really glad he did it too, and I congratulate him on having the highest output of the day.
There was an earlier comment about Daniel's engine building, and I have to say, he does a great job!
While the outputs are very good, the best thing about his tuning, is that my engine runs as smooth as silk, and it's very happy to lug around at very low speeds too - unlike many hot engines I've had in the past.
My car is happy to pull 6th gear from as low as 40km/h, yet scream its little head off when required.
You've got to be happy with that!
