What's the light humming noise you can hear from the engine bay when you turn the ignition to the "ON" position?
Reason I ask:
A couple of days ago my NB8A would start and then stall right away which is weird because it had no symptoms leading up to this. I did notice that the humming was not there when I turned the key to ON. Anyway I started on the fuel pump diagnosis instructions from miata.net, removed windblocker, started to pull the plug/clips holding the carpet on the parcel shelf, decided I wanted the windows down, turned ignition to ON and noticed the humming had returned so I tried my luck and she started, which is great, but now I'm wondering why she stalled to begin with. Maybe my tinkering alleviated some earthed wires and it has something to do with that humming...
Pat.
