MX-5 Club of NSW Dyno Day - 29 August 2009
Moderators: Andrew, -alex, miata, Midori
- StanTheMan
can't wit to see some of the results
- Regie
- Vehicle: NC - V8
see you all in a few hrs
- Regie
- Vehicle: NC - V8
good day, thanks for organising.
ill sort through some pics and see what i have.
88rwkw for me 252torques
- Charlie Brown
Well I warmed up the dyno for the first run of the day before I had to rush off.
The extractors DO make a difference.
105rwkW and 286Nm torque
I saw Hammers run and that's all.
I'll let him tell you what he got.
- Hellmun
- Vehicle: NB8B - Turbo
My car made a whole 90kw atw but it did pull 298nm of torque. Wish I could rev mine a little further...the power was just climbing and climbing until the rev limiter kicked in.
Good result CB....nearly got there but had to work at the last minute.
BTW, You need to change your location to Shark infested water....
Rob
- Guran
- Vehicle: ND - 1.5
My stock NA6 pulled a rampaging 71rwkW and torque at peak power was 198Nm . Peak torque was around 220Nm reading off the printout graph. I think that was the lowest numbers for the day, but still respectable compared to the 74-76rwkW for the two NA8s.
Amid a cloud of smoke and backfires, Richo's turbo pulled 197rwkW!!!
- CoffeeBoss
- suntory
Charlie Brown wrote:Well I warmed up the dyno for the first run of the day before I had to rush off.
OK, I'm starting to think your avoiding me now. Was wondering where you were!
Guran wrote:I think that was the lowest numbers for the day, but still respectable compared to the 74-76rwkW for the two NA8s.
Precisely. It shows your old jalopy hasn't really lost much over the years. Was reading the same in EVO not long ago, where they strapped an NA6 to a well known dyno and were genuinely surprised at the results.Guran wrote:Amid a cloud of smoke and backfires, Richo's turbo pulled 197rwkW!!!
One would think so! Should do plenty more once it gets tuned. Richo's such a classic, he had a serious case of performance anxiety prior to his run
- StanTheMan
what were the results for some of the modded NA6's?
- StanTheMan
105rwkW and 286? torque
meh......NA6's can get that.
*goes for cover*
awesome result regardless Phil.
- Charlie Brown
CoffeeBoss wrote:Charlie Brown wrote:Well I warmed up the dyno for the first run of the day before I had to rush off.
Sorry about that but we are moving house on Friday and the amount of packing is unbelievable.
I would have loved to have come at 11:00 and caught up with everyone.
WOW!!! Richo pulled 197 rwkw...and i also heard Georges car got around the 185?? rwkw
must be those Daniel Deckers engines
- marcusus
105! Wow. That's a fairly solid figure there Phil.
I'm kinda surprised Mark's only came up with 90 though? I would've thought it'd be a bit closer to 100 than that considering the power mods you've got going on.
- Hammer
Guran wrote:My stock NA6 pulled a rampaging 71rwkW and torque at peak power was 198Nm . Peak torque was around 220Nm reading off the printout graph. I think that was the lowest numbers for the day, but still respectable compared to the 74-76rwkW for the two NA8s....
Damn!!!!
71kw for an NA6 is mighty impressive. My stock NA8 only made an extra 5kw but it's nearly 50kgs heavier (and that does not include the driver )
Well done.
- Guran
- Vehicle: ND - 1.5
Hammer wrote:Guran wrote:My stock NA6 pulled a rampaging 71rwkW and torque at peak power was 198Nm . Peak torque was around 220Nm reading off the printout graph. I think that was the lowest numbers for the day, but still respectable compared to the 74-76rwkW for the two NA8s....
Damn!!!!
Well done.
Thanks Alan. Sorry I missed you on Saturday but there was no chance of me making it to Hornsby any sooner. Btw I'm running 14 degrees timing which supposedly gives more top end. Maybe you could try that if you're not already? Takes five minutes with a timing light - I can do it for you if you like.
Users browsing this forum: No registered users and 184 guests
