Lugcentric or Hubcentric?
Adam_NAclubman
Postby Adam_NAclubman » Sun May 24, 2009 12:11 pm
I've never run them on any of my cars and I've never had a problem. I'm very particular about the way I support the wheels when I put them on so that it's sitting properly square and doesnt use the nuts to pull it into position though
Postby Okibi » Sun May 24, 2009 1:42 pm
feeback noted. :lol:
CheyneX5
Postby CheyneX5 » Sun May 24, 2009 8:07 pm
Thanks for all the input guys :|
I tried using the search function, no luck.
90' NA6 - Classic Red
d-mag
Road Track Rally
Vehicle: ND - Turbo
Postby d-mag » Sun May 24, 2009 8:26 pm
1red5 wrote:
16bit wrote:just put them on, end thread.
x 1,000,000
X Eleventy gazilion
MX5 Wanted. SE or NC (forced induction preferred :twisted: )
wun911
Postby wun911 » Mon May 25, 2009 7:56 pm
I asked the same question when I got my enkei RPF1 wheels
viewtopic.php?f=30&t=35195&p=456131&hilit=hubcentric+rings#p456131
On miata net there is like a 10 page discussion on these things...
every ounce counts
Benny
Postby Benny » Tue May 26, 2009 5:30 pm
The car will run well whether you have the rings on or not, providing the wheels are put on properly to begin with.
The risk you run when not using the hub rings is that when you take the car for service, the grease monkey who will rotate your wheels may not be so careful with them and then you run the risk of the studs having to take all the stresses of the wheel.
When you use the rings, a lot of the pressure is put onto the hub, which it is designed for and the studs are not really designed to take all the loads, especially the sideways loads you put on them when cornering in a spirited manner.
There are hub rings made from aluminium and also plastic, and they weigh virtually nothing, just a few grams, so for some peace of mind, I would always put properly fitted hub rings on.
Every wheel and tyre place has a large selection of them, and they cost very little, so do yourself a favour, and go and get a set and put them on.
corners
Vehicle: ND - Supercharged
Postby corners » Wed Aug 26, 2009 11:45 pm
Sorry to bring up an old topic but I am curious to know where you would get hubrings from?
PUR157
Postby PUR157 » Thu Aug 27, 2009 5:24 pm
Most tyre shops should be able to get them for you
Just give them the inner and outer diameter you need
for MX5 is a 53mm inner (I think...)
Oneness of Man and Machine
Steampunk
Postby Steampunk » Thu Aug 27, 2009 8:37 pm
PUR157 wrote:for MX5 is a 53mm inner (I think...)
54.1mm to be precise :wink:
TonyMax
Re: Lugcentric or Hubcentric?
Postby TonyMax » Tue Aug 30, 2011 8:43 pm
We found this thread via a search, and by my research given some hub rings are made of plastic I can see them doing SFA in taking the load of the car from the wheel studs and nuts.
I don't think we'll be bothering getting any if the aftermarket 15s we end up with have a larger centre bore than the MX5 hub size.
~the artist formerly known as MizMac~
Postby manga_blue » Fri Sep 02, 2011 12:56 pm
If you're Catholic and went to a Marist or Christian Brothers school then you should get hubcentric, otherwise lugcentric is fine.
greenMachine
Postby greenMachine » Fri Sep 02, 2011 11:43 pm
manga_blue wrote:If you're Catholic and went to a Marist or Christian Brothers school then you should get hubcentric, otherwise lugcentric is fine.
That is the most convincing argument in support of hubrings that I have yet seen. 8)
Go straight to the top of the class Manga, and on the way I will give you an elephant stamp... :lol:
:mrgreen:
Users browsing this forum: No registered users and 100 guests
