pop ups not working
Mr_Q
pop ups not working
Postby Mr_Q » Sat Nov 15, 2008 10:05 am
I had that on both my NAs. Fixed it by replacing the retractor relay, which is under the steering wheel. Sorry, I don't recall the part number but you can pull it out and check.
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
Fuzzlet
pop ups not working
Postby Fuzzlet » Mon Nov 17, 2008 10:55 am
On my NA the lights would come up but not down....I eventually got it to work by re-jigging the wiring, didnt even think of the relay haha
stoffs21
pop ups not working
Postby stoffs21 » Mon Nov 17, 2008 4:19 pm
Hey mate,
I have the 92, same issue as all of you. Just replaced the relay, under the steering column. Problem fixed.
madboy
pop ups not working
Postby madboy » Fri Dec 19, 2008 9:25 pm
anyone have that part number on hand? looks like i have the same issue :?
Big G
pop ups not working
Postby Big G » Sat Dec 20, 2008 3:41 pm
madboy wrote:anyone have that part number on hand? looks like i have the same issue :?
Here's a pic of the relay
Geoff
Growing old disgracefully in Queensland
Founder of Eastern Region[HMF] Sunshine Coast Chapter.
1990 Mariner Blue Roadster
Verithin Guitars
pop ups not working
Postby 93_Clubman » Wed Dec 24, 2008 9:12 pm
Imasen LA12 is also listed as an MX5 headlight retractor relay.
ruckyboy
pop ups not working
Postby ruckyboy » Wed Aug 19, 2009 12:53 pm
FYI:
I had a similar problem with my relay - the headlamp switch wouldn't pop the lights up or down but the console switch worked.
The Mazda part no is : B481 67 7COB - list cost as of today $258.00 inc GST
Yeah, so I gagged.
However - gave it to an electronics tech I know and he fixed it up good as new for $60.00, apparently the caps had dried out and a trany had fizzed.
That saved $199 - :mrgreen:
Benny
pop ups not working
Postby Benny » Tue Aug 25, 2009 3:10 pm
ruckyboy wrote:FYI:
Yeah, so I gagged.
Rell, you certainry are rucky!
ruckyboy
pop ups not working
Postby ruckyboy » Tue Aug 25, 2009 3:32 pm
Benny wrote:
*Facepalm*
:lol:
devolutio
pop ups not working
Postby devolutio » Tue Aug 25, 2009 10:38 pm
i've got an intermittent headlight retractor relay problem... using manual switch on dashboard keeps them up but if i forget about 5 mins into driving the lights just go straight down. freaky the first time it happened. tried to find the relay to replace it but didn't have much luck. anyone got a picture of where it is under the dash?
ruckyboy
pop ups not working
Postby ruckyboy » Wed Aug 26, 2009 1:09 am
devolutio wrote:i've got an intermittent headlight retractor relay problem... using manual switch on dashboard keeps them up but if i forget about 5 mins into driving the lights just go straight down. freaky the first time it happened. tried to find the relay to replace it but didn't have much luck. anyone got a picture of where it is under the dash?
Hi devolutio,
no picture, but just remove the plastic panel under the column - 2 philips screws
you'll find it on a cluster of relays - hopefully pushed into one of the arms, it's the one with 6(?) pins in a U shape, about the size of 2 matchboxes.
mhj
Vehicle: NB8A - Supercharged
pop ups not working
Postby mhj » Sat Aug 29, 2009 7:31 am
the best and final solution to this problem is..... gets ready to run and hide.... buy an NB
enjoy
mhj
Users browsing this forum: No registered users and 264 guests
