Wazman's NB8a
wazman
Wazman's NB8a
Postby wazman » Wed Aug 19, 2009 8:49 pm
I'll cut and past some in the tech section then :P
The pump is quiet as........ can only hear it if your listening for it 8)
ilovedrift.com
dorifta
Wazman's NB8a
Postby dorifta » Mon Aug 24, 2009 1:24 am
Hey dude it's djemz from ns. Just got myself an nb same colour as yours and before I complement u on your progress I'd just like to say your a jerk for buying the wheels I wanted!!!
My nb also wobbles a bit at a constant speed but I'm told this goes away after cage and/or hardtop? Looking forward to hearing your experience with it!
For the pod, do you have to run that breather return so everything runs smoothly or is it simply for EPA? In the 32 hose from catch can goes straight to the ground!
get busy living or get busy dying
wazman
Wazman's NB8a
Postby wazman » Mon Aug 24, 2009 11:05 pm
Hey man, I intend on making a catch can for the breather soon as...... atm its just swinging in the breeze :mrgreen:
the roll bar seemed to help the with a more solid feel to the car......though i'm just about to go test it.......(its raining out 8) )
ilovedrift.com
devolutio
Wazman's NB8a
Postby devolutio » Tue Aug 25, 2009 12:50 am
hey waz, yeah i found the feel of the car changed a lot after installing the brown davis roll bar. i noticed a bit more tightening with a strut brace but nothing like the roll bar. you should try a hard top - i'm always amazed with the difference in feel that provides in winter.
dorifta
Wazman's NB8a
Postby dorifta » Tue Aug 25, 2009 3:59 am
devo can you post up some photos of a BD roll bar in an nb? I'd like to see how they compare to the mx5plus ones
Wazman's NB8a
Postby Jeo » Tue Aug 25, 2009 11:50 am
dorifta wrote:devo can you post up some photos of a BD roll bar in an nb? I'd like to see how they compare to the mx5plus ones
Have a search mate, there would be hundreds of photos of them on this forum.
wazman
Wazman's NB8a
Postby wazman » Tue Aug 25, 2009 11:47 pm
If your wondering how i drilled the holes for the rear of the cage with the roof on........i used this handy tool 8)
I got the bar powder coated satin black.
The final install was a little trickier than i imagined. I had to leave the seat belts out and fit the seat belt tower plastic's. I had to reach in behind them to get the nuts started on the bolts, then bolted the seat belt back in.
ilovedrift.com
wazman
Wazman's NB8a
Postby wazman » Tue Aug 25, 2009 11:57 pm
I wasn't real keen to have the adaptronic adaptor plug thingy just swinging around near the passengers feat all open like it is so i went to Jaycar and got a box for it.....Just a generic one....
Just hacked it up with a hack saw until the adaptor fitted in....
ilovedrift.com
Mokesta
Wazman's NB8a
Postby Mokesta » Wed Aug 26, 2009 9:03 am
Must have needed a big one of these.....
:roll:
wazman
Wazman's NB8a
Postby wazman » Sat Aug 29, 2009 3:19 am
What kind of retard would waste cash on something anyone can make :wink: + mines better for obvious reasons :lol:
ilovedrift.com
wun911
Wazman's NB8a
Postby wun911 » Sat Aug 29, 2009 11:50 am
whoa respect for work well done.... and nice pics
every ounce counts
dorifta
Wazman's NB8a
Postby dorifta » Tue Sep 01, 2009 10:19 am
wazman wrote:
I was given a pod filter by a friend.......so i bought a 90 degree silicon bend from supercheap ($40 on sale! wooo! ) Its a reducer bend....so its 2.5 inch at one end and 3 inch at the other......
I'm going to a winton fun day this sunday ($30 is cheap track time and its fun to go with a bunch of mates) so i'll let you all know how the coilovers performed when i get back.......
Hey man on the stock airbox... There is a plug that goes into the top part of the box... U can pull it out n looks like it's not meant to do anything at all.. What did u do with that thing as what is it?
And lol no I'm not talking about the afm
NMX516
Wazman's NB8a
Postby NMX516 » Tue Sep 01, 2009 11:37 pm
^^ It's the air temp sensor.
dorifta
Wazman's NB8a
Postby dorifta » Wed Sep 02, 2009 12:11 am
NMX516 wrote:^^ It's the air temp sensor.
do we need it? im guessing it can just dangle close to the mouth of the pod?
edit: will this do?
http://cgi.ebay.com.au/NEW-SILICON-BEND ... 286.c0.m14
AB7
Wazman's NB8a
Postby AB7 » Wed Sep 02, 2009 9:34 am
edit: will this do?
Yes you do need it, I drilled the silicone hose and put the rubber grommet.
In my case I put it close to the TB.
Wazman, nice work!!!
