Which spark plug?
Which spark plug?
hey all
i went to order some spark plugs from autobarn n they only had bosche stuff left.. so i took watever was right for the mx5...
i took out the current plugs in my nb8a n they are bkr6es? i thought this was a bit odd but are they the right plug to get?
thanks in advance
thanks in advance
get busy living or get busy dying
- philz
- Wheel guru
Which spark plug?
NGK BKR5E-11
Should be like $4 each, any auto store should stock them, even those small independent businesses.
- sliq
Which spark plug?
are the NGK Iridium IX over kill? worthwhile spending $18 a pop?
- philz
- Wheel guru
Which spark plug?
yes overkill, $18ea is a waste.
Not sure if the brk6 are too cold, but that's what's recommended on NGK site (brk5) I use them, no problems here.
Which spark plug?
They gave me Bosch FR 7 DCX+
Whats the comparison between Bosch and NGK
Which spark plug?
dorifta wrote:They gave me Bosch FR 7 DCX+
i'm not sure if it's proven or why, but the NGK seems to be favoured as better suited to standard or at least reasonably standard MX5s. my NA8 owners manual lists bkr5e11 or bkr6e11 as a recommended spark plugs, along with a couple of Nippon Denso.
- rodent
- 강남 스타일
Which spark plug?
Am I right in assuming the 6's would be a better match if you've bumped the timing to 14 degrees or more? Would it still be safe enough to run 91 octane in this configuration?
- Vehicle: ND - 2
Which spark plug?
I always use bosch,
I don't rally like the NGK series too much.
Bosch Super 4's for me all the way.
Wholesale Suspension
129 Coreen Ave
Penrith
pat@wholesalesuspension.com.au
02 4721 2112
129 Coreen Ave
Penrith
02 4721 2112
- Benny
Which spark plug?
rodent wrote:Am I right in assuming the 6's would be a better match if you've bumped the timing to 14 degrees or more? Would it still be safe enough to run 91 octane in this configuration?
If you've got your timing bumped up, I would be using Premium or 98 RON fuel to protect the engine from pinging.
When your timing is advanced, the chances of pre-detonation increase substantially, so using a higher RON fuel will give you some protection against it.
- rodent
- 강남 스타일
Which spark plug?
Yeah with bumped timing I'd always be using 98, but there have been situations in the past where it hasn't been available so I've had to throw in some octane booster which isn't great for the engine in the long run either. But it sounds like using a cooler plug won't help things anyway, oh well. Thanks for the tip George
Which spark plug?
What's this timing cheat? How's it effect fuel economy and lastly can it be done with nb8a?
- PUR157
Which spark plug?
That would be the "timing bump" "timing advance" it's been described as on this forum
Enter that as a search query and you'll get a little more info
But if I remember right it cannot be done on the later BPs, at least not as easily as the ones found in the NA, as timing in the NA is mechanically controlled
the NB BPs timing are controlled by the ECU?
Have I got that right?
Oneness of Man and Machine
- Garry
Which spark plug?
Using a plug one or two steps cooler can help with pinging. That's why SP's should use the bkr7e11. Though Mazda persist in putting in the bkr6e11 when I get my car serviced.
Which spark plug?
Shouldn't you gap the plugs on se to 0.8? That's what all us Nissan boys run on anything above stock boost
