What do Swaybar Endlinks do?
matt9111
Postby matt9111 » Thu Aug 20, 2009 8:09 pm
Hi everyone,
I've just bought some Whiteline Adjustable Swaybars and I was just wondering what Swaybar endlinks do?
If they're good for anything I'll get them too.
Great looking 02 BLACK NB8B, Tein S Tech Coils, Whiteline Adjustable Sways F&R, Carbing Alloy Rear Strut Brace ;)
Hellmun
Postby Hellmun » Thu Aug 20, 2009 10:09 pm
You already have them standard. They connect the sway bar to the lower control arm. The ones from whiteline let you adjust them. Basically it lets you play with the pre-load on the swaybars which lets you fine-tune the suspension. So inducing more understeer or oversteer depending on whether you adjust the front or rear pair.
Juffa
Postby Juffa » Thu Aug 20, 2009 10:11 pm
The sway bar is attached to the suspension by the end link. You would already have an end link on each end of your front and rear factory sway bars. Do you mean adjustable end link?
Read more here.
http://www.racingbeat.com/resultset.asp ... mber=54201
J
matt9111
Postby matt9111 » Fri Aug 21, 2009 2:16 am
Lol, yeah I meant the adjustable ones, and I thought the Adjustable swaybars, allowed you to play around with under/oversteer
mhj
Vehicle: NB8A - Supercharged
Postby mhj » Fri Aug 21, 2009 9:35 am
so if your sway bars are not adjustable can you use the adjustable end links to acheive a different tune instead?
mhj
rascal
Postby rascal » Fri Aug 21, 2009 10:09 am
Hellmun wrote:Basically it lets you play with the pre-load on the swaybars which lets you fine-tune the suspension. So inducing more understeer or oversteer depending on whether you adjust the front or rear pair.
Actually the adjustable bars themselves control the oversteer/understeer setting of the car.
The adjustable endlinks just allow you to adjust preload on the bar which can marginally affect how the car reacts to the sway bars..
Usually the adj end links are adjusted to ensure that there is no preload on the bars.
Adjusting both of the front or rear end links at the same time wouldn't do anything for steer characteristics. Would just lower or raise the end of the bar relative to the chassis.
CT
Postby CT » Fri Aug 21, 2009 10:42 am
Sway bars are designed so the arms are parallel to the ground when the car is static. When you lower the car, you need shorter end links otherwise the sway bar will be preloaded and the ends will be pointing up. It is highly advisable not to preload a sway bar this way as it can induce unwanted handling characteristics.
wun911
Postby wun911 » Fri Aug 21, 2009 12:14 pm
My car is lowered so will I need these or is it advisable to get these... also how thick can we go before we have to strenghten the swaybar mounts???
every ounce counts
rascal
Postby rascal » Fri Aug 21, 2009 1:28 pm
You dont have to have them.. ( mine is lowered and doesnt have them..)
Just means the sway bar wont be exactly as the factory designed it..
It would change the rate of the swaybar marginally due to the increased angle the linkages are working in..
and you 'may' end up with some preload on the bar..
Wholesale Suspension
Postby Wholesale Suspension » Fri Aug 21, 2009 1:37 pm
rascal wrote:You dont have to have them.. ( mine is lowered and doesnt have them..)
Agreed.
What he said is spot on.
Yes, it will preload your bar somewhat, but not too a point of changing the handling of the car, most of you would not even begin to notice it. I didn't when I did mine.
The preload amount is different for everyone depending on how low your car is. if your car is 30mm to 50mm lowered you would not even blink at it.
CT is on the money with his comment's but for the real world application, it is not a must do thing. IMHO. :)
Josh
129 Coreen Ave
Penrith
pat@wholesalesuspension.com.au
02 4721 2112
Postby Wholesale Suspension » Fri Aug 21, 2009 1:44 pm
wun911 wrote:My car is lowered so will I need these or is it advisable to get these... also how thick can we go before we have to strenghten the swaybar mounts???
You could usually go upto around the 27mm mark or more before you need to change the mounting hardware, we do a kit that can do this, but is not a must for anything under that size. (talking about front size)'
For the rear usually around the 22mm to 24mm. (which is really heavy bars, even the race cars don't go that big from memory)
What size bars do you run Chris? (CT)
Cheers Josh
129 Coreen Ave
Penrith
02 4721 2112
rascal
Postby rascal » Fri Aug 21, 2009 1:49 pm
Josh,
what options do you have for mounting hardware?
I've got aftermarket bars (24f/14r) on my track NB8A and while have had no issues so far, (only 2 meetings), am aware that NBs are prone to cracking the std mounts, so was interested in finding out what options there before it does happen..
Russ
Postby Wholesale Suspension » Fri Aug 21, 2009 1:54 pm
rascal wrote:Josh,
Russ
We can do a heavy duty universal D bush kit, includes fatter D's and also high tensile steel wider brackets, as for the bolts cracking the stud mounts, I really can't do anything about that i'm sorry.
I would really leave it the way it is for now though, the wider brackets really are going to be of no help really, it's the problem of the stud mounts that you need too look into. maybe ask some other the other racers what they have done too fix this issue.
Cheers Josh
129 Coreen Ave
Penrith
02 4721 2112
matt9111
Postby matt9111 » Fri Aug 21, 2009 6:21 pm
Thanks for clearing that up everyone, maybe once the car is heaps lower I'll get some, but won't worry for the moment.
Matty
mhj
Postby mhj » Sat Aug 22, 2009 9:48 am
my car is lowered with standard shockies....and i have broken an link without being mean to the car...from these posts that suggests that they are loaded inncorrectly?!?!...so should i get the beefed up or adjustable thingies??
enjoy
mhj
