POWER-ANTENNA FOR N/A
Stu
Postby Stu » Sat May 30, 2009 11:33 am
Calling MeanMX, your favourite topic is on the forum :mrgreen:
JBT
Postby JBT » Sat May 30, 2009 5:04 pm
I think about the only type that will fit is the Mazda one.
Benny
Postby Benny » Thu Jun 04, 2009 5:37 pm
Save yourself the hassle and just put a rubber duck antenna on it.
That way, you won't have to worry about a relay either.
PhilM
Postby PhilM » Tue Aug 04, 2009 10:29 pm
Did you have any luck getting an ant?
I need one as well - I cant leave the ant up as I pull over a cover.
Phil
Rosso Corsa Red NA V Special
RG.net
Postby RG.net » Tue Aug 04, 2009 11:51 pm
i have my power antenna for sale.
viewtopic.php?f=44&t=37729
pretty sure it will work with the NA's, i'm sure someone can confirm here.
PhilM
Postby PhilM » Wed Aug 05, 2009 8:58 am
Thanks for the reply mxhevn -
The NA has a short distance from the guard to the wheel arch. So if yours is about 250mm or less from the part that goes under the mud guard to the lowest point (water drain exit to the pipe).
I will also need the male plug if you have it -as mine just has + & - wires with round wire connectors - but I can solder them to the correct plug.
If thats OK we will have a sale
Phil
RG.net
Postby RG.net » Wed Aug 05, 2009 12:29 pm
PhilM wrote:Thanks for the reply mxhevn -
Phil
this is the factory NB antenna, i'm sure its a similar length to the NA antenna, as they are located in the same position, but on opposite sides.
Locutus
Postby Locutus » Thu Aug 06, 2009 1:22 am
pretty sure NB isn't direct fit because the shape of the rear quarter panels and positioning of antennas are different. NAs have the antenna mounted on a flatter surface.
PhilM
Postby PhilM » Fri Aug 07, 2009 9:45 am
Thanks Locutus -your right
I checked out a neighbours NB yesterday - I did not pull his internal boot liner to check the length. I think I can cut the wedge shaped rubber grommet at a lower angle to suit the NA.
I have a manual retractable aerial on now that is short enough but it is is not sealed - designed to go in a mudguard that is drained to the outside- in theNA it drains in the boot when it rains.
I'll buy MXHEVN s - If its too long I'll resell it back to a NB.
Phil
PhilM
Postby PhilM » Mon Aug 17, 2009 8:39 pm
Well I bought MXHEVNs electric NB - but unfortunately its about 60mm too long for the NA . so its on the market again - same price -$100.00
So pm me if you need an NB elect arial.
corners
Vehicle: ND - Supercharged
Postby corners » Tue Aug 18, 2009 3:10 pm
Where is the best place to get a rubber antenna from?
Postby bruce » Tue Aug 18, 2009 4:12 pm
Any rubber antenna is suitable, but you will need an adaptor as the threads are a different diameter. I bought mine for a store many moons ago.
Regards car covers, just cut a slit into it for the rubber antenna.
