Lug nuts (Aftermarket wheel nuts)
Wivvix
Postby Wivvix » Tue Aug 11, 2009 2:04 am
So i'm just wondering if anyone has tried tuner lugs on their aftermarket wheels, what one could recommend?
I've looked at Rays, Work, 5zigen, Enkei, Blox, Type One Racing, Mcgard, so on and so forth.
Aluminium vs Chromoly vs steel?
Locking nuts or not?
I have Enkei RPF1's, and am concerned that my existing chrome plated steel lug nuts are rubbish. They are showing signs of corrosion where the hex-tool is inserted into the lug nut. Not to mention the fact they are heavy.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Tue Aug 11, 2009 8:05 pm
i use 949 racing items for the track and normal speco steel ones for the street. both have held up well so far. they seem to hold the torque and don't loosen.
www.949racing.com
mr_rotary
Postby mr_rotary » Wed Aug 12, 2009 2:14 pm
I had the Work aluminium nuts on my GT-R. They didn't scratch and weighed next to nothing. Also comes with a locking nut. Bloody awesome and highly recommended and will again purchase soon for my RX-7 project.
They come in black, blue and red.
AB7
Postby AB7 » Wed Aug 12, 2009 3:58 pm
I have McGard, reasonable price & great quality. IMO Rays lugs is way overpiced, you wont notice the difference in weight.
Postby sliq » Wed Aug 12, 2009 6:12 pm
AB7 wrote: you wont notice the difference in weight.
wun would :lol:
wun911
Postby wun911 » Thu Aug 13, 2009 12:54 am
Yeah I hear the rays are very expensive and not that lite...
every ounce counts
blackster
Postby blackster » Thu Aug 13, 2009 12:36 pm
X2 on work lugs
Lite, work and appear great on my RPF1's, just torque them up to wheel specification, from memory on the 16" it was 85-120 nm.
Previous
04' MX5 SE.
02' MX5 Classic ed.
greenMachine
Postby greenMachine » Thu Aug 13, 2009 2:32 pm
Those 'Work' nuts look the same as the ones I got from Goodwin - but without the locknuts.
Look good, but after lots of use on the GM swapping racetyres on and off they started to show aluminium through the finish - didn't affect performance though, and they only went on the race wheels anyway so I didn't care.
Wivvix
Postby Wivvix » Thu Aug 13, 2009 6:10 pm
Thanks for all the input guys.
It's nice to get some discussion happening, particularly some light being shed on certain products based on actual experiences.
I've had a look at the 949 racing lugs and the Work lugs.
I can't decide which style will look better on a red NA8 with silver RPF1's :( . I saw some silver 15's on a red integra with ocean blue lugs (darker than valve color) which looked v clean.
There aren't a lot of pics which show the car side on, side it's kinda hard to tell what will look good...
I think polished ones will blend in too much.
Where did you guys buy your lugs from?
Cheers :)
mr_rotary
Postby mr_rotary » Fri Aug 14, 2009 2:41 pm
Mine came with the car however I'll be probably purchasing my next set off E-Bay.
philz
Wheel guru
Postby philz » Fri Aug 14, 2009 2:51 pm
Lots of honda traders have colours lug nuts (also honda has same pitch/thread as mazda), to name a few jdmyard, jdmconcept, and shift performance have cheaper lightweight ones.
tuned_to_fly
Postby tuned_to_fly » Fri Aug 14, 2009 2:53 pm
The new AutoSalon issue has a wheel nut comparison including dimensions & weights which might be useful.
CoffeeBoss
suntory
Postby CoffeeBoss » Fri Aug 14, 2009 4:08 pm
McGard user here. Look good with my RPF1s, no issues whatsoever. Just have to remember to lecture tire shops/service depts against the use of rattle guns if they are removing your wheels.
Or swap over to stock lugs before such time.
wun911
Postby wun911 » Fri Aug 14, 2009 9:01 pm
looks nice on the enkei wheels...
every ounce counts
wun911
Postby wun911 » Thu Aug 27, 2009 12:54 pm
I was reading apparently the turbo xs titaninum lug nuts are the litest 11 or 12 grams each. but they only do 1.25 and M12.
But its easy to change studs and angle grid them down...
every ounce counts
