Show us your custom number-plate mount!
Postby bruce » Fri Aug 07, 2009 12:53 pm
davekmoore wrote:Dunno about regulations in VIC or Oz in general but when I used to have an original Elan (yes, I'm very old) you were allowed to have a stick-on front number plate. Can we do that here and, if so, where to get the plate from?
That would be a no. Only the metal plates issued by Vicroads are legal. Get a slimline plate if you don't have one.
davekmoore
Postby davekmoore » Fri Aug 07, 2009 12:57 pm
Shame though, eh?
Postby hks_kansei » Fri Aug 07, 2009 2:12 pm
MX5CHIC wrote:Being that people just love reversing into me I am seriously considering options on mounting the number plate - some great ideas here. Has anyone tried using high density foam rubber behind the plate?
Hot Rodders has put some adhesive foam on the back of his plate bracket to help protect the bumper.
Postby sliq » Fri Aug 07, 2009 4:02 pm
MX5CHIC wrote:I might even consider a pressure sensitive alarm input so if the plate is forced back more than a few millimetres it trips the alarm .....
a standard microwave sensor does that, if you tune it spot on.
i was in a car park last time and a ute came quite close to my car... my car beeped 4 times to warn them that they were too close.
MX5CHIC
Postby MX5CHIC » Fri Aug 07, 2009 4:25 pm
Not sure where I'll mount the number plate yet but if it's in front of the bar I will use the foam rubber.
Should think about that before I put the bar on, would not have helped with the last guy who backed into me - he was Deaf :shock:
Does your microwave sensor also sound the alarm when people walk past?
Postby bruce » Fri Aug 07, 2009 4:47 pm
Put a switch behind your plate attached to the horn. Use it to touch park !
MX5CHIC
Postby MX5CHIC » Fri Aug 07, 2009 4:58 pm
Why not go all out and install bumper bar Airbags .. or has Volvo already done that? :?
Postby sliq » Fri Aug 07, 2009 5:07 pm
MX5CHIC wrote:Does your microwave sensor also sound the alarm when people walk past?
no.. it used to sound when someone/something came very close to the side mirrors, but i toned down the sensitivity.. so it only detects big masses.
Postby 93_Clubman » Fri Aug 07, 2009 5:44 pm
Shame though, eh?
sure is:
MX5CHIC
Postby MX5CHIC » Fri Aug 07, 2009 7:22 pm
Unfortunately it will never happen here, in the UK they have major problems with people using tape / pens or paint to modify their plates for stealing petrol etc.
I like the plate mounting from underneath the car - been playing with various positions before my new bar goes on this sunday.
Someone has the plate mounted on the lower part of the bumper opening and has a spring hinge - the plate drops flat at around 30kmh.
Postby 93_Clubman » Fri Aug 07, 2009 7:32 pm
MX5CHIC wrote:Unfortunately it will never happen here, in the UK they have major problems with people using tape / pens or paint to modify their plates for stealing petrol etc.
like the sound of that - i saw post with a photo of an na with the # plate mounted down low - not bad, but even better a little higher & hinged!
MX5CHIC
Postby MX5CHIC » Fri Aug 07, 2009 10:56 pm
Here is the thread containing the hinged number plate ....
http://forum.miata.net/vb/showthread.php?t=334634
Postby 93_Clubman » Sat Aug 08, 2009 1:03 am
ah hinged at the top - wtg as, in some states at least, # plate needs to be at the furthest forward point of vehicle. not sure if you've seen this for nb8a: http://www.miata.net/garage/swingplate.html
davekmoore
Postby davekmoore » Sat Aug 08, 2009 10:38 am
[/quote]
That would be a no. Only the metal plates issued by Vicroads are legal. Get a slimline plate if you don't have one.[/quote]
So if I get a stick-on front plate with the correct size, colours and font etc from the UK (which will be missing the VIC dwn the side) and put it somewhere reasonably visible, how much unwanted attention might it attract and how much might that attention cost me in AUD?
Postby 93_Clubman » Sat Aug 08, 2009 12:30 pm
Dave, you could get something made locally that replicates look, but is slightly smaller. That way, at least when mobile, it would attract little, if any, attention. However, when stationary it would be another matter...
Black max advised in '05 in NSW "there is 2 fines and depends on how nice the cop is - The one I got was drive vehicle with illegal numberplate - No points lost but a $78 fine - the 2nd option is about $980 and 3 points for obstruct or obscure numberplate"
http://www.aus-cartalk.com/forum/viewto ... highlight=
Bruce mentions in '06 that in Vic the fine had gone upto $130 at some point.
If you're still interested then try the following as they're quoted as having supplied stickers in '06: SCOTCH-LINE CENTRE P/L, Unit 30 / 148 Chesterville Rd Moorabbin (03) 9532 0660
Users browsing this forum: No registered users and 256 guests
