turbo or supercharged?
dorifta
Postby dorifta » Mon Jul 27, 2009 5:23 am
guys wats the fine in victoria?
i have got 2 defects in 2 weeks driving a 240kw skyline around so im used getting used to the boys in blue!
im guessing its an epa inspection, defect and emissions fine?
get busy living or get busy dying
1.6lAutorotor
Postby 1.6lAutorotor » Thu Jul 30, 2009 9:18 pm
That sounds about right Dorifta.
I have been running modifications for a long time thankfully the boys in blue don't look at an mx5 too closely. The only extenal mods i have are 16" wheels. So you can get away with it, but i don't know what would happen in an insurance claim.
Sell your car buy a standard turbo, i was young and didn't do enough research when i bought mine and the SP was a pipe dream.
dorifta
Postby dorifta » Fri Jul 31, 2009 3:33 am
when you say buy a standard turbo... do you mean buy an SP?
they are kinda out of my price range :S
1.6lAutorotor
Postby 1.6lAutorotor » Fri Jul 31, 2009 10:05 am
Yes SE or SP.
If you need more power than the standard MX5, I'd say they are cheaper in the long run.
mhj
Vehicle: NB8A - Supercharged
Postby mhj » Sat Aug 01, 2009 6:29 am
x2 on the sp/se....or is it x222
personally i wouldnt go an unengineered modified mx5 ...trouble with the plod is one thing...trouble with the cars development is another...but the real clincher for me is the potential for trouble with insurance and in turn claiiims.
alternately...wait til you get lucky( as im pleased to say i did) and find an already engineered car someone else has put the time and $$ into
enjoy
mhj
dorifta
Postby dorifta » Sun Aug 02, 2009 7:04 am
Has anyone got info on what exactly needs to be done for engineering?
My rb25det into r32 cost around the $1200 mark for the engineers cert (thats not including box/motor/brakes ect)
Unfortunately I cant afford a se/sp... was thinking something along the lines or nb8a + trust turbo kit with td05 15g (roughly $700 + delivery) and get a not so loud exhaust made up... internally gated sucks though :(
1.6lAutorotor
Postby 1.6lAutorotor » Sun Aug 02, 2009 8:53 pm
When I was looking it was about 3000 for the emisions test. This was the biggest hurdle if you turbo your car you might be able to get the emisions data from the sp and use that (same engine). The 1.6 was never sold in oz with forced induction so it was a pain. I belive the avo stage 1 kit was complianced so you might want start there. The enigneers I spoke to said they wouldn't look at the car till I had that. Once I had the pass on emisions it was 500 to certify it barring any neccesary upgrades, brakes etc. Emissions is the biggest hurdle in Melbourne.
Don't forget the standard clutch won't stand up to more than 3-4 pounds for very long and the fuel pump and injectors are on the small side so the tuner will probably want to replace them mine did. Some wider rims and an LSD don't hurt either.
mhj
Postby mhj » Mon Aug 03, 2009 6:52 am
im not the greatest expert,but
bigger injectors for fueling saftey..tick..but you could get away without themif cost is problematic
clutch is fine with 6 psi maybe more...just dont do too many burnouts and drop the clutch type behaviours
fuel pump is also fine until higher boost than 6psi
happy to stand corrected, but this is what ive got without an issue( nb with jrsc45.. almost 6 psi)...and i have had the input fom mx5 mania and i did invite them to sell me stuff.
enjoy
mhj
dorifta
Postby dorifta » Tue Aug 04, 2009 3:24 am
a friend of mine was over in japan not long ago and he saw the kit at store like our autobarn...
wow i never knew the emissions test was so expensive.. maybe before I went from turbo motor (rb20det) to turbo motor (rb25det) i didnt need to get it?
me thinks sleeper nb is coming :)
