[BRAKES] slider pins - grease?
Jace
Postby Jace » Mon Aug 03, 2009 9:18 pm
going to install some EBC greenstuff pads tomorrow night.
figure i might as well give the pistons a good greasing and check everything over while i'm at it.
what sort of grease do you recommend and why?
i've got some high temperature bearing grease in the shed, probably what i'll use if i'm not advised against it.
JBT
Postby JBT » Mon Aug 03, 2009 9:32 pm
Use brake grease. http://tinyurl.com/lxcct3
wun911
Postby wun911 » Tue Aug 04, 2009 12:12 am
you can buy high temp caliper grease...
every ounce counts
corners
Vehicle: ND - Supercharged
Postby corners » Wed Aug 05, 2009 8:08 pm
JBT wrote:Use brake grease. http://tinyurl.com/lxcct3
OH MY GOD that link is AWESOME!!!!
corners
Postby corners » Wed Aug 05, 2009 8:09 pm
Also I just went to the local brake shop told them what I wanted and they just gave me a small amount of grease to use!
Jace
Postby Jace » Thu Aug 06, 2009 12:30 am
bursons had nothing silicone based. guy told me to use HTB grease. eh. slippery stuff is slippery stuff to me.
JBT
Postby JBT » Thu Aug 06, 2009 7:58 am
Why bother asking our advice then :?: Use petroleum based grease on your brake system at your peril. :shock:
Users browsing this forum: No registered users and 110 guests
