When Your Engine Eats # 4 Rod Cap & Piston
- wtnmiatas
This is what it looks like. Got the piston & bent the rod & cap up like a pretzel. Happen on my 99 Miata.
91 BRG - 5sp - Life is too Short not to have Fun and Enjoy
- Ando
Eeeek!!!!
Man, what a mess. I'm assuming the car stopped dead in it's tracks?
Ando
~ 1999 Twilight Blue NB8A ~
1として馬そしてライダー
Ando
1として馬そしてライダー
- wtnmiatas
Ando wrote:Eeeek!!!!![]()
Was rolling down the interstate 40 here about 70mph. Heard a bang & pop clutch it & pop it out of gear & costed over to the side of the interstate with a dead engine. Hour later on the hook haveing it taken home.$$$ Was hoping it was the timming belt but she was locked up. Pulled the plugs & # 4 plug gap was hammer closed. So I pulled the head & saw what made the bang & pop.$$$$$$$
- JBT
Is this the result of the dreaded #4 thrust bearing failure problem with the 99 model?
- wtnmiatas
JBT wrote:Is this the result of the dreaded #4 thrust bearing failure problem with the 99 model?
I dont think so it had over 143,000 miles on it. I found one of the #4 rod bolt nuts in the bottom of the oil pan. Think it came loose & cause the crank bearing to spin an then the nut came all the way off. The thrust bearing wasnt beat up etc. The head - block & crank are ok.
- Benny
You're really lucky it didn't ventilate the block!
I'd be checking the condition of the bore in #4 very closely though.
- wtnmiatas
Benny wrote:You're really lucky it didn't ventilate the block!
There was a small nick about a inch long in the bottom of cylinder where the rings dont go down that far. 4 or so up & down passes with a engine cylinder honer cleaned it up.
- Benny
Thank goodness you can save it then.
Might be a very good excuse to bore it out a little.
