Custom gauge dials * finished with pictures
- Vehicle: NB Roadster
well im going to give this a crack
http://www.revlimiter.net/mods/gauges.html
what i was wondering is if any one already has taken theres apart to install custom guages and might have the metric speedo spare that i could use to scan in before i rip mine apart? if i can do up a template id be more than happy to share it with any one else who is intrested
cheers
Paul
cheers
Paul
1998 NB MX5, AVO turbo kit, Adaptronic plug'n'play, RX8 440cc injectors, Fm Brace, DBA cross drilled brakes, cusco rollbar Pedders springs
- Tedsmx5
- Vehicle: NA8 - Supercharged
custom gauge dials
Looks like a good project (but I'm not allowed sharp things ), pictures please when you give it a go.
Ted
Ted
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
custom gauge dials
progress so far
pretty much trying for a retro look kind of old lotus type deal
- slug_dub
custom gauge dials
Nice work.
I've got the template from Revlimiter.net downloaded as well for a crack as soon as I find some time. I look forward to seeing how yours look once installed!
custom gauge dials
one thing i have noticed is that the template appears to be for a na does any one know if this will be an issue? are they pretty much the same setup ?
- Kain
custom gauge dials
psquire, did you end up getting a scanned image for metric gauges? I reckon this looks awesome. If you've got a template to share that'd be fantastic.
- Szemen
custom gauge dials
For his "mask layer" he uses normal paper. Is that alright? Are the LEDs bright enough to shine through them?
custom gauge dials
well after tinkering around this morning ive discovered that the template doesnt match up to nb dials so im going to make up a new one for nb's which ill post up here hopefully this afternoon
he uses normal paper as long as you use something like copy paper i.e. 80gsm it should be fine i wouldnt use anything over 100 gsm paper for it tho
im using a special paper its a xerox brand ( plug) called never tear its a kind of plasticy type thing that is quite thin but as the name sudgests is quite strong and light seems to come through it quite easily
im also tinkering with a couple ideas to do white gauges so ill see how that works out
custom gauge dials
well ive come up with a new templatefor nb dials if any one can host it or point me in the direction of some where ill stick it up
cheers
paul
cheers
paul
custom gauge dials
psquire45 wrote:well ive come up with a new templatefor nb dials if any one can host it or point me in the direction of some where ill stick it up
cheers
paul
www.tinypic.com
custom gauge dials
thanks for that adam but ill need to find a file uploading service as i dont think that site will let me upload an illustrator .ai file
heres an update anyway this is what im sorting out at the moment
custom gauge dials
well ive had some progress not all of it good but what can ya do
ive managed to get a trial set together and in the car which roughly fit although theres some light leaking past the sides of the dials because the fit isnt perfect thsi is my own fault due to not measuring properly because my home scanner was down
how ever ive done the scan now at work and have a nice 300dpi image to upload for people playing the home game
ive also found that if you follow the original tutorial and have the top layer as a transparency the dials are quite shiny and reflective so i may try it with just high quality copy paper (xerox) plug
anyway ill post some pictures up of the trial gauges when i can
cheers
Paul
cheers
Paul
custom gauge dials
well ive finished up my white gauges im happy with them for now well at least until i get another crazy idea theyre basically a knock off of the standard gauges only with white faces and everything lights up blue
the first picture is of the first attempt which came up very shiny and i wasnt particularly happy with the layout of the
the second is of the new ones with the different layering to avoid the shinyness
the third is all installed new sexy awesomeness
i really dont think this is the best mod ive done to the car so far but it is definatley the cheapest seeing as all the materials i knocked off around the office
the new layering technique that i used was reasonably simple i used a plain sheet on top i used a polyester paper but normal copy paper should have similar results then used two transparency sheets printed with black details to block out the light coming through in areas where i didnt want it and then a solid sheet of blue printed on transparency on the back to tint any light that does come through
- Benny
Very impressive.
As you went to so much trouble to do this, you should have put your name on the gauge faces!
i considered it but then i would get emails etc asking for help lol and it does seem a bit "HEY LOOK AT ME"
Users browsing this forum: No registered users and 258 guests
