Torsen owners
Torsen owners
Postby Regie » Tue Jul 28, 2009 1:15 pm
I'm getting my torsen installed tomrrow. Just wondering if there is any special oil to put in there? Or just the STD LSD will do?
lil red rocket
Vehicle: NA6 - Turbo
Torsen owners
Postby lil red rocket » Tue Jul 28, 2009 1:20 pm
Talk to Danny at MX-5 plus SERVICE . He has intalled one also. He should know
phone (07) 3265 1112
or email service@mx5plus.com.au.
042 9999 485
Regards Brian H
lil red rocket aka blue chilli
[color=#BF00FF]I like it! I like it a LOT!
http://www.cardomain.com/ride/3368773/3
Hellmun
Torsen owners
Postby Hellmun » Tue Jul 28, 2009 2:20 pm
It's standard gear oil. No friction modifiers needed like in a clutch pack diff. It'll be the same oil you run in an open diff which is 75/90 from memory.
Torsen owners
Postby sliq » Tue Jul 28, 2009 2:58 pm
same as gearbox oil..
jerrah
Torsen owners
Postby jerrah » Tue Jul 28, 2009 4:55 pm
I'm just running Castrol gear oil in mine.
How often should I be changing it?
1991 MX5
JBT
Torsen owners
Postby JBT » Tue Jul 28, 2009 5:13 pm
Just use the same oil as recommended for the open diff and change it at the same intervals.
Steampunk
Torsen owners
Postby Steampunk » Tue Jul 28, 2009 7:20 pm
JBT wrote:Just use the same oil as recommended for the open diff and change it at the same intervals.
ditto
Torsen owners
Postby Regie » Tue Jul 28, 2009 8:13 pm
sweet thanks!!
im looking forward to some sideways action :)
StanTheMan
Torsen owners
Postby StanTheMan » Wed Jul 29, 2009 8:27 am
the torsen is a fabulous mod. I love mine
philz
Wheel guru
Torsen which one?
Postby philz » Wed Jul 29, 2009 10:44 am
Well anyways since the question has been answered, I will hijack it.
Which torsen/ratio would you guys recommend for nb8a standard 5 speed?
StanTheMan
Torsen owners
Postby StanTheMan » Wed Jul 29, 2009 10:45 am
4.1:1 which is standard anyway.
Szemen
Torsen owners
Postby Szemen » Wed Jul 29, 2009 11:12 am
Might as well put my question here then...How do you confirm you have an LSD? Peer in during a diff oil change?
Steampunk
Torsen owners
Postby Steampunk » Wed Jul 29, 2009 11:31 am
Szemen wrote:Might as well put my question here then...How do you confirm you have an LSD? Peer in during a diff oil change?
Park one rear wheel on grass/dirt/loose surface and the other on clean bitumen.
Rev her up, dump the clutch;
- if the wheel that is on the loose surface continues to spin, then you have an open.
- " " " " " " " " " stops spinning within a split second and the wheel on bitumen gets more drive (may start spinning also) then you have LSD.
Sailor
Torsen owners
Postby Sailor » Wed Jul 29, 2009 11:42 am
Jacking the rear of the car and rotating one wheel...If the opposite rotates same direction you 'may' have an LSD.
Does this work with the Torsen?
Rob
JBT
Torsen owners
Postby JBT » Wed Jul 29, 2009 11:47 am
The tests above won't necessarily work on a Torsen diff because, if one wheel loses traction, it will behave the same as an open diff. Clicky
