Hi all
I currently have some no name strut brace, currently off the car as the engine got swapped.
When previously fitted it used to make contact with the PCV valve and bend it a little.
Just wondering if anyone can tell me if the whiteline braces do this?
Jaron
Whiteline Strut Brace NA6
- corners
- Vehicle: ND - Supercharged
- StanTheMan
doesn't look like its anywhere near the PCV valve
- corners
Cheers I was sent pics but couldnt see the PCV Valve!
The picture I was sent shows the brace facing the other way......
- StanTheMan
you can also install the bacckets the other way around which would bring it closer to the PCV valve but I doubt it would actually touch it.
- corners
StanTheMan wrote:you can also install the bacckets the other way around which would bring it closer to the PCV valve but I doubt it would actually touch it.
I think I will run with your way as I wouldnt mind reinstalling my Master Cylinder stopper.
Users browsing this forum: No registered users and 217 guests
