Rear Axle Nut direction
G'day wise ones,
Can someone please tell me which direction you are suppose to rotate the nut in order to get it off the rear axle nut?
none as yet - looking for a white NA8
- Vehicle: ND - 2
counter clock wise
they are torqued to about 170pounds/ft so they are floweringly tight, the big forum advises using 3/4" sockets and a loooooooooooong breaker bar or, more preferably, an air wrench.
A job for the local diff guy. Whist it is apart, bang on a few new boots too.
- StanTheMan
yea mine was tigheter than a nuns pussy.
I had a 1m extension braker bar with an 85Kg Craig jumping on the end of it to get it to open. The other side was just as tight. The car ended up being lifted off its jack stands with the lift.
I used 1/2 inch socket set but I have heard them braking when attemting to open theses bolts up
another solution would be to go to a tyre place get them to open it with a rattle gun. Then drive it home semi tight......but slowly.
I forgot to mention... the halfshaft and hub is off the car already... so its going to be even harder to remove the nut.. I've tried a 1/2" drive on a rattle gun with no luck.. this nut is TIGHT!
I've got no way of securing the shaft to prevent it from rotating with I break the nut with a bar..
- StanTheMan
- StanTheMan
Apply the handbrake. If it slips.....may need a bit more ajustment. If it still slips.......I have no solution then.
- StanTheMan
right.... just re read your post......the halfshaft is off the car......the nut is on the shaft but in no way attached to the car? handbracke isn't going to help you. no matter how well adjusted.
my appolgies
if i'm imagening this correctly......you may need to cut it off with an angle grinder
my appolgies
One of the secrets to removing tight fasteners is heat- ie the nut will expand. From what I have gathered home rattle guns may not have enough torque/ grunt- businesses have big guns and lots of air. You could hold the half shaft in a vice with soft jaws or simply take it to a mechanics shop.
- StanTheMan
so how did you go boost.....did you get it off?
- philz
- Wheel guru
Even with a 4ft cheater bar on the breaker bar, the hand brake couldn't hold it.
Get someone to press on the foot brake, to apply even more pressure, this got the nut off for me.
- StanTheMan
But I think in this case I don't thing the halfshaft was attached to the car
- philz
- Wheel guru
But if you can get the half shaft out, it means the nut is already off right?
Unless one side (diff side) is off only.
- StanTheMan
Not neccecaryly.....picked it up 2nd hand & the bolt has kind of rusted to it.
- ampz
- Vehicle: NA6 - Turbo
If the hub is still on the halfshaft get a bar (pinch bar, breaker bar piece of pipe) between 2 of the wheel nuts/studs, then use the socket and breaker bar with the nut as a pivot.
Imagine a pair of scissors, with the nut as the fulcrum point.
If you can get them close enough together (like cable tie the 2 bars together) and stand it vertically...
Get a big boy (the chunkier the better) to jump on it.
It works with my 100kg's worth of... knowledge
Huh?
Users browsing this forum: Bing [Bot] and 220 guests
