Grille VS No Grille
MX5CHIC
Grille VS No Grille
Postby MX5CHIC » Fri Jul 10, 2009 7:44 pm
I have previously replaced an Air Conditioning Condensor due to a stone hitting it, so it begs the question as to whether to fit a Grille or to take your chances without one?
I have just made up a second grille for my NB8A in the pursuit of decent looking protection, after having a good look I have decided I will paint it black over the weekend ... cost under $60 for parts - your opinions?
If you have a great looking grille please post up a photo for all to see .. I'm interested in other options.
Grille VS No Grille
Postby sliq » Fri Jul 10, 2009 7:50 pm
i have a great looking grille FS lol
it looks good mx5chic, but would prefer it black. more stealth.
Duj
Grille VS No Grille
Postby Duj » Fri Jul 10, 2009 8:09 pm
Id love to buy an NB8A grille if anyone has one they'd like to sell me...? :)
Currently driving an 01' GS300 2jz...
MX5CHIC
Grille VS No Grille
Postby MX5CHIC » Fri Jul 10, 2009 8:14 pm
Yes Sliq I will definitely make it black, black is good :lol:
Pamex
Grille VS No Grille
Postby Pamex » Fri Jul 10, 2009 8:58 pm
I concur with the 'go black'.
This is going to sound ghetto in the worst possible way... but I actually have a strip of metal gutter guard cable tied in as mine. No, seriously, it works. Plus it's set quite far in, so you can't see it.
When it's full of bugs I just replace it with a new strip. :mrgreen:
NMX516
Grille VS No Grille
Postby NMX516 » Fri Jul 10, 2009 9:03 pm
I had a stainless steel grille fitted for a while - looked ok, but in the end I removed it because I had coolant temp problems at the track. Was fine in normal driving though.
I thought I would have had a decent pic showing it on the car but I don't :| Another vote for painting yours black MX5CHIC
Edit: Oh what the hell, here's a poor attempt at a grille pic: (this thread needs more black 5's anyway :P ) You can see the grille if you look closely, very closely.
Steampunk
Grille VS No Grille
Postby Steampunk » Fri Jul 10, 2009 10:43 pm
NMX516 wrote:....I had coolant temp problems at the track. Was fine in normal driving though.
What he said.
Mine didn't overheat, and the needle on the dash didn't move higher than normal, but datalogging via MegaSquirt showed temps 5-8degrees Celcius higher with the grille on.
It's no biggie, but I took it off whilst on track just as a precaution.
here's one I prepared earlier :P
RG.net
Grille VS No Grille
Postby RG.net » Fri Jul 10, 2009 11:59 pm
i had a grille for a while, ended up getting over it.
Paint it bleck.
Grille VS No Grille
Postby Hammer » Sat Jul 11, 2009 2:28 am
I had a "Techno" grill (finished in stainless steel weave pattern) that I had for a long time. It was removed when I fitted the SE front spoiler (in May this year) and haven't bother to fit it back.
Plus everyone recommended that I don't put any grill in-front of the intercooler.
MX5CHIC
Grille VS No Grille
Postby MX5CHIC » Sat Jul 11, 2009 8:44 am
I'll be trying to stick with a grille, the Air Con Condensor $320 + Dryer / Receiver (has to be replaced if gas is lost) $73 + ReGas $140 ... over $500 damage from one well placed high velocity stone ..... :cry:
Get back to you with a pic of the Black Grille :D
Grille VS No Grille
Postby sliq » Sat Jul 11, 2009 9:02 am
were you actually aware when the rock hit the condensor? pull over to the side of the street?
MX5CHIC
Grille VS No Grille
Postby MX5CHIC » Sat Jul 11, 2009 9:56 am
No I was not aware at all .. until I switched on the A/C and no cold air! Inspected the Condensor and found a piece of Gravel in the fins with an obvious leak around it. Bummer.
RG.net
Grille VS No Grille
Postby RG.net » Sat Jul 11, 2009 3:16 pm
its times like this when i'm glad i removed my A/C :mrgreen:
Thats gotta suck though.
MX5CHIC
Grille VS No Grille
Postby MX5CHIC » Sat Jul 11, 2009 4:05 pm
Well here is the Grille in full Black + MX-5 Badge
Grille VS No Grille
Postby sliq » Sat Jul 11, 2009 6:11 pm
mx5 chic what happened to the badge on the front bar?
Users browsing this forum: Bing [Bot] and 0 guests
