Wazman's NB8a
wazman
Wazman's NB8a
Postby wazman » Sat Jun 06, 2009 4:30 pm
The ASI raditor fitted perfect no probs.....everything lined up fine.
Yeah i'll be getting the guards rolled after i get coilovers....
ilovedrift.com
lukey
Wazman's NB8a
Postby lukey » Mon Jun 08, 2009 11:03 am
Very nice Waz
I cant wait to see the finished result
1997 MX5 Montego Blue - Gone
1999 MX5 Brilliant Black - Gone
2004 MX5 SE Titanium - OOOOOHH BABY!!!!
'Jinbai Ittai' - Rider and Horse as one
RG.net
Wazman's NB8a
Postby RG.net » Fri Jun 19, 2009 8:02 pm
any updates wazman? :mrgreen:
wazman
Wazman's NB8a
Postby wazman » Tue Jun 30, 2009 5:55 am
YAY !!!! Stuff came today in the mail and it wasn't bill's ! :D wooooooo 8)
Payed for em late thursday night and they rocked up 9:30 mon morning from NZ...... Good Game! (GG)
One set of BC coilovers $1199 + $100 delivery off ebay.....
Here comes the install....... Some may not approve of my methods.....But there in and i didn't leak a single drop of blood= GG
I've heard rumours that these coilovers are made in the same factory that produces the "Greddy/trust" coilovers..... My housemate has greddy's in his silvia and the similarities in build quality and labeling is uncanny....... :roll:
I find the idea of having holes in the side of the bottom cup where the thread is...... a little confussing, wouldn't it just let more water/crud in to corrode the thread? ......the drainage hole at the bottom makes up for it though...... the JIC's i had in my 180sx didn't have this feature :?
ilovedrift.com
wazman
Wazman's NB8a
Postby wazman » Tue Jun 30, 2009 6:17 am
I thought i took alot more pic's at the time but once i uploaded em there aint that many :(
ilovedrift.com
wazman
Wazman's NB8a
Postby wazman » Tue Jun 30, 2009 6:25 am
I decided to start with the rear.... Because i new it would be easiest......Undo the sway bar, it makes moving seperate sides up and down much easier....
Pull out the trim in the boot and the metal fuel hose guard to get access to the strut top bolts....I loosened these until just a few threads remained, so i can just reach in and undo by finger whilst holding up with other hand when it come time to take out.
I didn't have a pic of undoing the standard strut top but you get the idea...... Below you cant see but i have the rusty pole jambed through the top wishbone to push the whole lot down so i can get the strut out......Its tucked under my arm while i take photo and grab strut :lol: ......
Very handy to have in your garage..... 1 piece of 1.5m x 38mm rusty pipe ! :mrgreen: Rusty pole is a must for quick and easy one man coilover installs 8)
Here you can see the length difference between stock and BC (with base screwed all the way on as far as it would go) but with NO preload on the spring, just held firm by a couple of turns....
ilovedrift.com
wazman
Wazman's NB8a
Postby wazman » Tue Jun 30, 2009 6:31 am
^^^^ And yes thats the height i'm putting them in at ! :mrgreen:
ilovedrift.com
wazman
Wazman's NB8a
Postby wazman » Tue Jun 30, 2009 6:43 am
If you've ever had a set of seized up coilovers before and tried to get em moving then you'll appreciate what i'm doing here....A small amount of grease onto the thread inside the height adjustable base. Yes i'm male and no i didn't read the instructions......i just do stuff like this...
This is the awkward reach/feel around in the dark for a thread to put your nut onto..... Hold it up while you try get the nut on :roll:
ilovedrift.com
Wazman's NB8a
Postby sliq » Tue Jun 30, 2009 10:08 am
8)
nice work
Pamex
Wazman's NB8a
Postby Pamex » Tue Jun 30, 2009 10:20 am
Awesome write up. That's coming along a treat!
I concur on the rusty pole. I was lacking a rusty pole when I did mine so super awesome purple wheel brace sufficed. :roll:
Oh and KAAZ LSD... Wow. Nice.
Wazman's NB8a
Postby Hammer » Tue Jun 30, 2009 10:53 am
Wicked! 8) I too am considering swapping the springs and shocks of my NB.
This is a very good pictorial "How-to". Very handy for a newbie, like me.
I might IM you for more hints and tips. Like, what tools did you end up using etc. :mrgreen:
Wazman's NB8a
Postby Jeo » Tue Jun 30, 2009 3:53 pm
I like what I see :) Needs completed pics asap
Wazman's NB8a
Postby Okibi » Wed Jul 01, 2009 2:37 am
Pamex wrote:.... I was lacking a rusty pole when I did mine so super awesome purple wheel brace sufficed. :roll: ...
I used a mattock :lol:
wazman
Wazman's NB8a
Postby wazman » Wed Jul 01, 2009 4:11 am
Sorry i fell asleep before i could finish.....
Here's some more...
Undo the strut top nuts all the way....
If your suspension has never been undone before then nuts will be tight....Enter the old double spanner technique :|
use "Old rusty" to lever the suspension down so you can undo lower strut bolt and remove with fingers....(after you've loosened it with rachet :roll: )
You have to undo the bottom ball joint thingy out of the lower control arm so you can drop it low enough to get the strut out.
this shows the hole where the bolt is under the bottom of the strut....never done this before..... i was making it up as i went... :roll:
This is how i got it out with only one pair of hands......and a foot... :wink:
ilovedrift.com
wazman
Wazman's NB8a
Postby wazman » Wed Jul 01, 2009 4:47 am
As your pulling the old/ stock strut out, remember which way you do so you can get the new one back in.....its kinda tight....
As with the rear i undid the sway bar to make things move easier...
All in and drove it around the yard a bit to settle it in......
One thing to remember kids....... Use stand or blocks and let the car down in stages..... I just dropped it and found the height was to low to get my jack out!
Yep i felt a bit silly..... :oops:
Now for some guard rolling so i can put my babies on :twisted:
Though first i knew that i would need more camber on the front to tuck my tyres in under the guards.....so i adjusted the lower control arm camber bolts out
as far as they would go......(Yes i'll be getting a wheel alighment later)
A quick phone call to a trusted guard rolling pro Athid.....This guys done merc's, beamers and Lexus's = trust!
This is what we are looking for...Buisness card clearance between tyre and guard 8) = stance ! GG
ilovedrift.com
Users browsing this forum: No registered users and 203 guests
