interior removal guide
- 16bit
anyone know where I could get hold of a free internets interior removal guide for my nb8a?
- Hammer
16bit wrote:anyone know where I could get hold of a free internets interior removal guide for my nb8a?
they miata.net
I've pulled most of ours apart as some stage.
I don't think I have photos for most though
, what did you need advice on removing?
- 16bit
Centre console and everything at the front (dash etch). Doors are no worries.
thanks!
thanks!
on the same topic, anyone know the weight loss by taking out carpets, sound deadening, softtop?
same boat, just want the bottom carpet out.
I'll do some fishing around guys.
16bit wrote:Centre console and everything at the front (dash etch). Doors are no worries.
thanks!
Centre console is easy, there are two screws in the centre console (pop the lid, you will see them) and there is one screw attached to the bottom of the dash on each side (they will be covered with a black plastic dot thingy) then you carefully lift it out, try not to damage the boot and fuel opener.
- sliq
http://www.miata.net/garage/DashRmv_89_93.pdf
that should help you with the dash removal 16bit.
Its for an NA, but its all very similar.
- 16bit
thanks mate, thats a big help. i am glad I did not just have a crack at it!
- de Bounce
MXHEVN wrote:Centre console is easy, there are two screws in the centre console (pop the lid, you will see them) and there is one screw attached to the bottom of the dash on each side (they will be covered with a black plastic dot thingy) then you carefully lift it out, try not to damage the boot and fuel opener.
Thought there was a screw under the electric window switch
At least there is in the NB8B
Getting the switch out is a PITA IMHO
- TieNN89
de Bounce wrote:MXHEVN wrote:Centre console is easy, there are two screws in the centre console (pop the lid, you will see them) and there is one screw attached to the bottom of the dash on each side (they will be covered with a black plastic dot thingy) then you carefully lift it out, try not to damage the boot and fuel opener.
Thought there was a screw under the electric window switchLink
At least there is in the NB8B![]()
yep on the NB8B+ consoles
on the NB8A its under the ash cup thing open it up and hold the lid and pull it upwards should remove it (should be pretty easy)
AZNTieN wrote:de Bounce wrote:MXHEVN wrote:Centre console is easy, there are two screws in the centre console (pop the lid, you will see them) and there is one screw attached to the bottom of the dash on each side (they will be covered with a black plastic dot thingy) then you carefully lift it out, try not to damage the boot and fuel opener.
I didnt have a screw there since purchase, lucky me.
- 16bit
failed at removing the dash! just could not get it loose. I got a bunch of other stuff out but I could not be bothered in the end.
16bit wrote:failed at removing the dash! just could not get it loose. I got a bunch of other stuff out but I could not be bothered in the end.
Why do you want the dash out anyways?
just strip the carpet, paint it and call it a day.
Users browsing this forum: Google [Bot] and 6 guests
