AVO/FM/BEGI
Monza02
AVO/FM/BEGI
Postby Monza02 » Mon Jun 15, 2009 2:52 pm
Righteo
I have spoken to Les and gained his sage advice.
I wants to turbo. I want to do it once and do it properly. I want a kit that I can spend the xmas break installing. Must be "complete".
it is a 2001 NB8B.
Clutch is new 6 puck brass button. Rest is stock. Adaptronic will be the ECU and Les has kindly referred me to a local tuner.
Anyone have any thoughts on the above three suppliers they wish to share?
wazman
AVO/FM/BEGI
Postby wazman » Mon Jun 15, 2009 11:44 pm
AVO turbo kit ?............ i havn't been able find many others..... cheap ebay junk that prob wont last.....
I am on a budget so will make my own kit........
ilovedrift.com
rxmx
Vehicle: NA6 - Turbo
AVO/FM/BEGI
Postby rxmx » Wed Jun 17, 2009 11:51 pm
I previously had an avo kitted NA8, never had any dramas at all with any of the hardware. For the money I'd def go with an AVO kit and save on shipping/taxes etc.
Im also in the process of a DIY turbo setup. Have got turbo/dump/ecu and stuffs already. I need to get a turbo manifold. Can anyone shed light on which manifolds are good besides AVO that i know of?
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
wazman
AVO/FM/BEGI
Postby wazman » Thu Jun 18, 2009 12:46 am
the only other thing i've found that seems to be half decent is this thing from flyin miata.......... (clicky the link)
http://www.flyinmiata.com/index.php?deptid=4524&parentid=0&stocknumber=22-21020
Though i got a bit over excited on ebay and bought a evo 7 turbo....(td05) Prob should have looked at it before i snapped it up.....everything is backwards on it :roll: the inlet for the exhaust housing is on the wrong side etc....because its off a east west mounted engin...so it will have to be top mount or side mount.......very custom manifold......lucky i live with a qualified welder :mrgreen: He already has the exhaust flange plotted on the laser cutter at his work.....though i dont intend on rushing into the project because i want it all to fit nice and work properly......
What turbo's do you guys intend on using ?
ilovedrift.com
rxmx
AVO/FM/BEGI
Postby rxmx » Fri Jun 19, 2009 12:15 am
Yah the FM manifold looks good...
Iv'e got an internally gated GT2876R with a .86 hotside which has got me a bit worried as i dont think it will spool very well so I need a manifold which will help spool up with my turbo. Was also looking at the ETD manifolds. They seem to be very well built.
$499 ceramic coated.
http://www.etdracing.com/store/product_ ... ucts_id=55
mx52nv
Purple Porsche Eater
AVO/FM/BEGI
Postby mx52nv » Fri Jun 19, 2009 12:47 am
rxmx wrote:Yah the FM manifold looks good...
Hi rxmx,
Why don't you just swap the exhaust housing for a 0.64 (off any Silvia turbo)? I think I remember seeing some complaints of clearance issues for the ETD manifolds on Miataturbo.net so do a little research first before you spend your money. It may have been only the external wastegates fouling so please check either way.
FM manifolds are my preference at the moment.
Les @ MX5 Shop
Phil @ P5
AVO/FM/BEGI
Postby Phil @ P5 » Fri Jun 19, 2009 9:15 am
I've fitted and tuned all 3 kits in my time. First started with AVOs, the BEGi/FM and now the new FM kits. All the kits have challenges.
BEGi - Quality control seems to be poor, as well as build quality. You're always seem to have to file, bend or cut something. Powder coating is poor.
AVO - Manifold is a PITA to fit due to the shape and the central nut requires a ground spanner and can be difficult to remove.
FM - Intercooler mounting isn't the strongest and the silicon piping isn't my favorite in terms of looks.
In terms of performance, I'd hand it to AVO. I've not seen a better intercooler from BEGi or FM, and I believe the manifold is the best flowing (although make sure it's got expansion cuts and don't drill it for an EGT probe; too thin). I saw 17psi on a NBB by 3300rpm and went onto top 310bhp.
Phil
rxmx
AVO/FM/BEGI
Postby rxmx » Fri Jun 19, 2009 6:22 pm
Hey Les,
I will def keep an eye out for a silvia housing, I wasnt sure if they were the same... So a housing from an S13/S14/S15 SR20 will be ok?
Thanks,
rxmx,
Monza02
AVO/FM/BEGI
Postby Monza02 » Fri Jun 19, 2009 7:51 pm
Phil @ P5 wrote:although make sure it's got expansion cuts
please expand
:lol:
Alex
AVO/FM/BEGI
Postby Alex » Fri Jun 19, 2009 11:33 pm
please expand
:lol:
There have been a few complaints about cracks in the manifold on the turbo forum
Monza02
AVO/FM/BEGI
Postby Monza02 » Thu Jul 02, 2009 3:26 pm
Thanks Phil
Sean
AVO/FM/BEGI
Postby Sean » Mon Aug 31, 2009 7:33 pm
rxmx wrote:Hey Les,
Thanks,
rxmx,
Make sure it has the same number of bolt holes as your current housing (particularly where the CHRA connects). From memory BB centres use a housing with more bolts than the non BB type.
Monza02
AVO/FM/BEGI
Postby Monza02 » Thu Apr 08, 2010 8:28 pm
update
took delivery of Begi stage 2 (with a 2560), walbro 255, 550 injectors and adaptronic p&p.
Just moved to a new house so the install will have to wait a couple of weeks while i clear the shed
charlie_91
AVO/FM/BEGI
Postby charlie_91 » Sun Apr 18, 2010 9:59 pm
awesome dude.. will be following this one :D
AVO/FM/BEGI
Postby Okibi » Mon Apr 19, 2010 1:51 am
Congrats Monty!
