SE Head on NA 1.8
- irwin83r
SE Head on NA 1.8
head should go on no worries.. space might be tight in the engine bay though
SE Head on NA 1.8
What sort of gains would you be looking at powwer/torque wise?
And what sort of cost to change heads on an NA8? would it be worth it over, say....changing cams in standard head?
Chris
Chris
viewtopic.php?f=73&t=62834
- Russellb
- RIP Nov 2014
SE Head on NA 1.8
evil_weevil wrote:What sort of gains would you be looking at powwer/torque wise?
Chris
Will fit without a problem
Power wise ? with the Link ECU should make 140 RW KW with out a drama
This is what my NA8 Made unintercooled
with an AVO manifold and Autronic SMC
Intake temps were over 100 Deg C at the track
My ClubmanRebuild
MX5 SE Rally car is HERE
- 16bit
SE Head on NA 1.8
i think the combustion chamber volume goes up by almost a third with nb8a on head. i am sure one of the members who have build a head could verify. you should be able to flow more with the newer head whether that results in power on a forced induction application on a streetable scale I am not sure. You can get away with quite a bit more 'inefficiency' in forced induction applications than you can in na applications. it would probably come down to the variables between combustion chamber pressure and volume that would yield the most favorable conditions for power. this gets into the area of danny territory i think.
SE Head on NA 1.8
So for a non turbo, na8 with basic mods - is it worth doing the head change or staying with standard head on na8 and just upgrading cams?
- Steampunk
