Teins - Are these any good?
Postby Hammer » Tue Jun 09, 2009 11:18 pm
Hi guys
What do you think of these Teins being sold from eBay? LINKY
The description says, the suspension kit is a "TEIN Type Basic Coilover Kit". I don't know anything about Teins and I'm not sure if these are good or not and if the price is great or not. What are the pros and cons of this model?
I've checked the Tein product catalogue and nothing refers to Tein Basic Coilover. Are they the same as the Tein Super Street Kit?
d-mag
Road Track Rally
Vehicle: ND - Turbo
Postby d-mag » Tue Jun 09, 2009 11:32 pm
They are same as Super Streets but without the damper adjust. Basically, just a height adjust coil over.
MX5 Wanted. SE or NC (forced induction preferred :twisted: )
Postby sliq » Tue Jun 09, 2009 11:33 pm
i've read mixed reviews about these... a balance of good and bad.. i'd need to be pretty convinced before buying something, and to be perfectly honest, i wouldn't be convinced in buying the basics.
i'd just go the whole hog and get the superstreets, particularly with a brand as reputable as tein.
Postby Jeo » Tue Jun 09, 2009 11:34 pm
Edit: d-mag beat me to it
Basic are the level below super streets. Basically the same setup without dampening adjustability.
AB7
Postby AB7 » Tue Jun 09, 2009 11:38 pm
Check out clubroadster.net
There quite a few review on them, mostly not very favourable. 2 months a go a local supplier in Melbourne is selling them for $700
blackster
Postby blackster » Tue Jun 09, 2009 11:48 pm
Hammer wrote:Are they the same as the Tein Super Street Kit?
No, there is no damper adjustment and with that kit you will have to use your OEM top hats. If your getting it professionally installed it usually means an extra cost.
US SS specs:
Fits : 99-05 MAZDA Miata (NB8C)
# SPRING RATE : Front : kgf/mm,lbs/in (Part Number) 7 / 392 (SQ040-01175)
# Rear kgf/mm,lbs/in (Part Number) :8 / 448 (SJ080-01200)
Spring Rate Adjustment Range (mm/inch) : 2/112~ -2/-112 & 2/112~-1/-56
# Ride Height (mm/inch) : Front : -41/-1.6
# Rear : -39/-1.5
# RIDE HEIGHT ADJUST RANGE (mm/inch) MAX ~ MIN : Front : -32/-1.3~ -62/-2.5
# Rear : -29/AS2 ~ -60 / -2.4
US Basic specs
Spring Rate Adjustment Range (mm/inch) : 1/56~ -1/-56 & 1/56~-1/-56
# Rear : -39/-1.5
Previous
04' MX5 SE.
02' MX5 Classic ed.
philz
Wheel guru
Postby philz » Wed Jun 10, 2009 1:35 am
IMO they aren't bad, they are just coilovers without the dampening adjustment.
So if you just want to lower the car they will do the job well, but if u want to fiddle with dampening etc, you would opt for the Tein Superstreet.
But SS go for $2k now with the okay exchange rate, but $700 they are a steal for brand new.
The only mixed opinions about Basics is they won't "slam" the car, and you don't have the ability to change the dampening, but they are pretty much identical to the SS.
pcmx5
Postby pcmx5 » Wed Jun 10, 2009 8:47 am
Big Al has them on his SP and is very happy with them.
I followed him on Sunday's club run and his car sat really well over bumps and flat through corners.
I hope he will give some feedback based on his experience.
Peter.
Adam K
Postby Adam K » Wed Jun 10, 2009 10:13 am
I recently put a set on my 2001, its a road only car and now sits a little lower. I think they are very worthwhile if you want a little lower and much fresher than the stock which will now be starting to age.
Postby Mr Morlock » Wed Jun 10, 2009 3:27 pm
see the local new Silver sponsor - Sydney based. Much better in my view to deal with local people who can give you face to face advice and provide warranty and back up. They would be able to fit if for you as well. We all have different requirements.
Postby Okibi » Wed Jun 10, 2009 4:32 pm
I couldn't have put it better myself. Thanks for promoting forum sponsors. :mrgreen:
love5
Postby love5 » Wed Jun 10, 2009 5:04 pm
Mr Morlock wrote:see the local new Silver sponsor - Sydney based. Much better in my view to deal with local people who can give you face to face advice and provide warranty and back up. They would be able to fit if for you as well. We all have different requirements.
As I understand it these 'unofficial' importers have to scratch off or remove serial numbers, therefore voiding factory warranty?
I believe the warranty the ebay sellers offer is with them not TEIN?
Perhaps our new sponsor can correct me if thats wrong? :?:
I know I would avoid them if thats the case.......
Previous - SP | Previous - 10AE
philz
Wheel guru
Postby philz » Wed Jun 10, 2009 5:12 pm
If they imported it via Japan, your warranty is with Tein Japan.
They don't have to scratch off the serial number.
Postby manga_blue » Wed Jun 10, 2009 6:03 pm
Here's Tein's own take on where their products sit
Adam K
Postby Adam K » Wed Jun 10, 2009 7:17 pm
When i called the australian distributor for Tein , they put me in touch with the store associated with the top web link. I have to assume they are legit aussie stock.
