Will MS-03 fit over NB8B Brakes on NA6??
MxJadeMonkey
Postby MxJadeMonkey » Fri Jun 05, 2009 11:00 am
Will the 15x7" Mazdaspeed MS-03 rims fit over NB8B brakes that have been fitted to an NA6? 8)
Simple question really, hope some one can help out?
Cheers Josh
1991 NA6 Velocity Blue (Ford Colour)
Postby bruce » Fri Jun 05, 2009 11:31 am
Doesn't sound like a simple question though....!
MxJadeMonkey
Postby MxJadeMonkey » Fri Jun 05, 2009 11:36 am
So I take it your someone who has not done this and has no idea about my question....
But thanks for your imput any way.
Alex
Postby Alex » Fri Jun 05, 2009 11:44 am
bruce wrote:Doesn't sound like a simple question though....!
It seems simple enough to me, basically has anyone fitted these rims on a NB8B/C without them hitting the brakes
philz
Wheel guru
Postby philz » Fri Jun 05, 2009 12:10 pm
Here is a more easy question, will nb8a wheels fit nb8b brakes, if so... they probably can fit.
credibility: I have ms03 wheels.
stevesports
Postby stevesports » Fri Jun 05, 2009 1:44 pm
well, not so simple. The problem here is the clearance of the caliper, rather than the disc. There are certain 15 inch wheels which would not clear the chunkier calipers. I think the RPF1 15' does not clear. I think this would possibly depend on the offset (correct me if i'm wrong) and how the wheel spoke is designed.
GS
Postby GS » Fri Jun 05, 2009 2:24 pm
I think Fuzzlet runs MS01's on his SE, so assuming the internal structure of the Mazdaspeed wheels is similar then the answer might be yes. I'd be interested to know what you find out about the clearance on the MS03's as well, as i need to upgrade my brakes sometime.
1989 NA6
project.r.racing
Postby project.r.racing » Fri Jun 05, 2009 8:35 pm
yes they will fit. nb8b brake ain't that big.
timk
Postby timk » Tue Jun 23, 2009 12:19 am
philz wrote:Here is a more easy question, will nb8a wheels fit nb8b brakes, if so... they probably can fit.
Yep, they fit.
Fuzzlet
Postby Fuzzlet » Tue Jun 30, 2009 7:06 pm
Yep I use MS-01s for thr track, and they clear the caliper by around 2 - 3mm, if that
Users browsing this forum: Google [Bot] and 2 guests
