Tein Install Guide or Manual
corners
Vehicle: ND - Supercharged
Postby corners » Wed Jun 03, 2009 2:04 pm
Hey
I bought some second hand Tein Flex's which I am gonna install soon, just wondering if someone knows of a manual or guide which shows how to adjust, height, spring tension and rebound?
Thanks
philz
Wheel guru
Postby philz » Wed Jun 03, 2009 2:04 pm
corners
Postby corners » Wed Jun 03, 2009 2:08 pm
Thanks Philz!! :D
corners
Postby corners » Wed Jun 03, 2009 2:09 pm
Also can anyone tell me that springs the flex comes with?
The ones I have have a light grey spring with Swift stickered on the side
philz
Wheel guru
Postby philz » Wed Jun 03, 2009 2:21 pm
You have swift springs. which are aftermarket springs for aftermarket coilovers.
They are usually replaced for a more stiffer spring rates.
Oh and normal stock Tein flex are 7/6
silvermiata
Postby silvermiata » Wed Jun 03, 2009 4:50 pm
also, having done the suspension 4 times on 5, easiest way to do the suspension is the "long bolt" method. basically take out the long bolt that holds the upper wishbone of the fronts, and take the suspension out, rear is a lot easier... big forum should have some detailed instructions..
Postby sliq » Wed Jun 03, 2009 5:17 pm
silvermiata wrote:also, having done the suspension 4 times on 5, easiest way to do the suspension is the "long bolt" method. basically take out the long bolt that holds the upper wishbone of the fronts, and take the suspension out, rear is a lot easier... big forum should have some detailed instructions..
agreed :wink:
stevesports
Postby stevesports » Wed Jun 03, 2009 6:17 pm
with regards to the rear suspension, it is easier but you must remove a bolt on, erm...the wishbone...such that you can push it down and replace the coil. I found it a bit more involved in my NB8B that others experienced for their NA's
corners
Postby corners » Mon Jun 08, 2009 9:48 pm
All installed and seems ok.
Did anyone have any issues with whiteline front sway bar hitting the shocks???
