DIY centre console
trader
DIY centre console
Postby trader » Fri May 01, 2009 5:55 pm
Been wanting to do this for awhile. When a mate gave me a lend of his nibbler I thought it was time to get started. Hope to build it for around $100 bucks...will show results as soon as I get the carpet overlocked.
NB SE, NA 1.8.
DIY centre console
Postby Jeo » Fri May 01, 2009 6:19 pm
One too many sets of image tags there Trader...
Looks interesting though, keep us posted.
trader
DIY centre console
Postby trader » Fri May 01, 2009 6:44 pm
Sorry - having trouble working this thing called imageshack!
NB SE, NA 1.8.
philz
Wheel guru
DIY centre console
Postby philz » Fri May 01, 2009 7:56 pm
A cheaper alternative of getting the Nakamae look.
trader
DIY centre console
Postby trader » Thu May 14, 2009 5:53 pm
Well I've just about finished it! Got to clean up how the carpet sits which means stitching velcro onto the carpet (tried gluing it but not successful). Found it to be a tricky job but at least it came in under budget - about $100 which is a lot cheaper than Nakamae. Re located the petrol opener in the boot.
NB SE, NA 1.8.
philz
Wheel guru
DIY centre console
Postby philz » Thu May 14, 2009 5:56 pm
Sweet good work!
This is a real one, and it looks just as good as it.
DIY centre console
Postby Jeo » Thu May 14, 2009 6:16 pm
Very nice. Well done!
16bit
Vehicle: NB8A - Supercharged
DIY centre console
Postby 16bit » Thu May 14, 2009 7:53 pm
nice work - i would do this but find the space handy. real good job mate.
DIY centre console
Postby sliq » Fri May 15, 2009 1:52 pm
philz wrote:Sweet good work!
from recollection that was a D-technique? the nakamae has the window switches on console, not dash?
Jace
DIY centre console
Postby Jace » Wed May 27, 2009 9:08 pm
that looks excellent!
what exactly have you used for the shape underneath the carpet?
if it was me, i'd rub the window switch and shifter surround back with P240 and P600 and leave it with a brushed sort of look to match your vent rings.
just a tip though. still looks great the way you've done it.
trader
DIY centre console
Postby trader » Thu May 28, 2009 6:42 pm
Thanks for the tip IH8. I think I will try roughing up as the polished SS surround (from ebay) it too obvious. Currently, console is off the car as I'm looking for an electric clock to put either below the switches or between the gearstick ring and switches (anyone got one?). If I did it again I would put the switches somewhere else. Ive just got 1/2" foam under the carpet which is velcro taped along the sides but thinking of glueing it down when finally finished.
NB SE, NA 1.8.
Jace
DIY centre console
Postby Jace » Fri May 29, 2009 9:11 pm
what material forms the shape? sorry to nag.
trader
DIY centre console
Postby trader » Sun May 31, 2009 5:48 pm
Sorry, I thought you meant the foam. A sheet of (offcut) 3mm aluminium.
NB SE, NA 1.8.
Jace
DIY centre console
Postby Jace » Sun May 31, 2009 11:27 pm
nah no worries.
might have a go at it soon.
trader
DIY centre console
Postby trader » Fri Jun 19, 2009 9:37 am
Dissapointed with the look of the window switches so have added a clock to tie them in. I think it looks a lot better. I kept a pattern of the carpet and aluminium if anyone needs them.
[img][IMG]http://img195.imageshack.us/img195/1002/img07251p.jpg[/img][/img]
NB SE, NA 1.8.
Users browsing this forum: No registered users and 270 guests
