Just wondering if anyone has an aftermarket ignition system?
I'm throwing around the idea of installing the system I have, but I'm not sure if the trouble/expense is worth it.
Any help as to exactly what the benefits are would be ace.
Aftermarket Ignition system?
- d-mag
- Road Track Rally
- Vehicle: ND - Turbo
MX5 Wanted. SE or NC (forced induction preferred
- philz
- Wheel guru
Is this for replacing the coilpacks? so u wanna convert to coil-on plug?
Splitfire DID make some for the mx5, now discontinued.
Though I have seen them twice on yahoo jp, one for na8 and na6.
Unless you wanna rig up your own set with Toyota 1zz COP, I'll glady assist in anyway:D
I'm really surprised a vendor isn't doing an upgrade system for all the NB owners with dead coil packs.
- CT
I use 4 Rav4 coils on my racer. The QLD boys have been doing it for years. Not sure I'd bother on a roady though as you need an aftermarket ECU to control it properly.
- d-mag
- Road Track Rally
Yeah CT, I'm running stand alone. One of these... http://www.linkecu.com/products/engine- ... er/g4storm
I'm not too sure how good, bad or otherwise it is. Or even whether it will control the the M&W's I've got. The car seems to run great ATM, so I guess it's doing it's job.
I would like to have this as more of a race car than a street car, if that helps. I guess if race cars are running them, they've got to be the way to go? I was just a bit unsure of the benefits over the standard NA8 coil packs.
This is the ignition system I have It's an M&W, although mines not installed yet.
- zoomzoom
- Vehicle: NA6 - Turbo
The 1ZZ coils seem to work well
- Novice1
Check out the multi spark coils used by Woo.
garage_modification.php?mode=view_modification&VID=7&MID=95
Cheers Novice1
Cheers Novice1
What is the benefits of replacing the std coil packs with 'coil on plug'?
