Im pretty sure the cam timing is off, any tips on how to get it right?
I had #1 at TDC, and set the dowels on the cams to 12 o'clock, but how can i tell if its a tooth off?
Anyone done cam timing who'd like to share?
JMather wrote:Have you checked your timing with the timing light? you may just need to adjust the cam angle sensor.
