Lugcentric or Hubcentric?
CheyneX5
Postby CheyneX5 » Sat May 23, 2009 2:13 pm
Hi all,
I just bought some 15x6.5 ROH wheels, i have 2 on the back and they seem to be going fine. But just for safety reasons, do i need hub rings for them?
90' NA6 - Classic Red
Postby Okibi » Sat May 23, 2009 2:27 pm
It's good to have them, they cost bugger all and weigh bugger all. I'd get them.
bensale
Postby bensale » Sat May 23, 2009 4:07 pm
I had a quick look at these wheels, the hub holes are tapered in like the nuts. It was my understanding that if the the holes and nut are tapered then wheel is located correctly by this and is therefore Lug centric and doesn't require hub rings.
I guess it couldn't hurt to get a set though.
www.othersideproductions.com
wun911
Postby wun911 » Sat May 23, 2009 5:05 pm
My understanding is you dont need them they are added weight...
every ounce counts
project.r.racing
Postby project.r.racing » Sat May 23, 2009 5:49 pm
since 100% of aftermarket wheels are supplied with them. i'd say you'd need them. locates the wheel directly to the centre of the hub. bolts will have some small tolerances.
Steampunk
Postby Steampunk » Sat May 23, 2009 6:41 pm
project.r.racing wrote:since 100% of aftermarket wheels are supplied with them. i'd say you'd need them. locates the wheel directly to the centre of the hub. bolts will have some small tolerances.
what he said
Simply put the wheel onto the bolts WITHOUT a hub-ring and if the centre hole is too big, the wheel will jiggle around.
As Okibi stated, get hub rings as they are cheap & weigh nothing.
wun911
Postby wun911 » Sat May 23, 2009 8:22 pm
My enkeis came with rings whats your OD they might fit you...
Seriously they do weigh something I haven't had a chance to weigh them yet but im pretty sure they weigh something...
every ounce counts
CheyneX5
Postby CheyneX5 » Sat May 23, 2009 8:25 pm
OD?
wun911
Postby wun911 » Sat May 23, 2009 8:35 pm
Its a ring so the numbers represent the ID inner diameter and OD outer diameter usually measured in mm.
The inner diameter is the same for both NA and NB, however the OD is dependent on what wheel you buy...
every ounce counts
Moto
Postby Moto » Sun May 24, 2009 2:06 am
Buddyclubs don't.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Sun May 24, 2009 10:50 am
just put them on, end thread.
philz
Wheel guru
Postby philz » Sun May 24, 2009 11:15 am
Buddyclubs don't.
Most don't come with them supplied because all cars a different, the tyre place have them.
Steampunk
Postby Steampunk » Sun May 24, 2009 11:18 am
16bit wrote:just put them on, end thread.
x 1,000,000
philz
Wheel guru
Postby philz » Sun May 24, 2009 11:20 am
wun911 wrote:My understanding is you dont need them they are added weight...
Well if you had lightweight wheels to begin with, this would make sense.
greenMachine
Postby greenMachine » Sun May 24, 2009 12:02 pm
:shock:
:roll: not another thread on this ... :roll:
Maybe the search function should be made bigger, brighter ... flashing daygo orange? What about it administrators?
:mrgreen:
