Lugcentric or Hubcentric?
- CheyneX5
Hi all,
I just bought some 15x6.5 ROH wheels, i have 2 on the back and they seem to be going fine. But just for safety reasons, do i need hub rings for them?
90' NA6 - Classic Red
It's good to have them, they cost bugger all and weigh bugger all. I'd get them.
- bensale
I had a quick look at these wheels, the hub holes are tapered in like the nuts. It was my understanding that if the the holes and nut are tapered then wheel is located correctly by this and is therefore Lug centric and doesn't require hub rings.
I guess it couldn't hurt to get a set though.
www.othersideproductions.com
My understanding is you dont need them they are added weight...
every ounce counts
- Vehicle: Non MX-5
since 100% of aftermarket wheels are supplied with them. i'd say you'd need them. locates the wheel directly to the centre of the hub. bolts will have some small tolerances.
- Steampunk
project.r.racing wrote:since 100% of aftermarket wheels are supplied with them. i'd say you'd need them. locates the wheel directly to the centre of the hub. bolts will have some small tolerances.
what he said
Simply put the wheel onto the bolts WITHOUT a hub-ring and if the centre hole is too big, the wheel will jiggle around.
As Okibi stated, get hub rings as they are cheap & weigh nothing.
My enkeis came with rings whats your OD they might fit you...
Seriously they do weigh something I haven't had a chance to weigh them yet but im pretty sure they weigh something...
every ounce counts
- CheyneX5
Its a ring so the numbers represent the ID inner diameter and OD outer diameter usually measured in mm.
The inner diameter is the same for both NA and NB, however the OD is dependent on what wheel you buy...
every ounce counts
Buddyclubs don't.
- 16bit
just put them on, end thread.
- philz
- Wheel guru
Moto wrote:project.r.racing wrote:since 100% of aftermarket wheels are supplied with them. i'd say you'd need them. locates the wheel directly to the centre of the hub. bolts will have some small tolerances.
Buddyclubs don't.
Most don't come with them supplied because all cars a different, the tyre place have them.
- Steampunk
16bit wrote:just put them on, end thread.
x 1,000,000
- philz
- Wheel guru
wun911 wrote:My understanding is you dont need them they are added weight...
Well if you had lightweight wheels to begin with, this would make sense.
- greenMachine
not another thread on this ...
Maybe the search function should be made bigger, brighter ... flashing daygo orange? What about it administrators?
Users browsing this forum: No registered users and 143 guests
