Jeremy Owen wrote:34psi - hmmm, doing some research (ie google) and maybe it is a bit high?
Yep. Try the recommended pressure or 30-32psi and see how it feels.
Guran wrote:Adrenalins are directional and assymetric. That means the front left can be swapped with the rear left, but not the front right. You should have two of each orientation!
Guran wrote:Adrenalins are assymetric and are NOT directional
Guran wrote:Hang on a minute! My previous comment was based on my assessment of the tread pattern only. I just checked the Adrenalins on two of my cars and also the RE050As on our third car. All have "outside" marked on the tyre wall indicating that they are assymetric. Correct. But the tread pattern does NOT reverse itself for left and right sides ie. all four tyres are identical. This is a shock to me because the tread pattern is obviously set up to maximize water pumping in one direction. They SHOULD be directional! I would predict this means that the drivers side tyres will have less grip in the wet because they'd tend to pump water into closed cavities rather than into the central ring. Perhaps this helps explain the questions that have been raised here about wet grip in the Adrenalins. Scary!
BTW the RE050As are the same except that the tread pattern is cleaner without any "closed loops".
marcusus wrote:Guran wrote:Hang on a minute! My previous comment was based on my assessment of the tread pattern only. I just checked the Adrenalins on two of my cars and also the RE050As on our third car. All have "outside" marked on the tyre wall indicating that they are assymetric. Correct. But the tread pattern does NOT reverse itself for left and right sides ie. all four tyres are identical. This is a shock to me because the tread pattern is obviously set up to maximize water pumping in one direction. They SHOULD be directional! I would predict this means that the drivers side tyres will have less grip in the wet because they'd tend to pump water into closed cavities rather than into the central ring. Perhaps this helps explain the questions that have been raised here about wet grip in the Adrenalins. Scary!
The correct direction for water dispersion is away from the tyre itself, irrespective of whether it goes left or right. The fact that the adrenalins are asymmetric is a moot point, so long as it moves the water away from the tyre.
I for one don't find there to be much problem with my adrenalins in the wet. Of course grip isn't going to be as good as in the dry, but I don't find them to be ridiculously worse when in the wet.
Perhaps people are just hammering along in the wet without really changing their driving style to suit the conditions, hence the complaint about their wet weather performance?
Users browsing this forum: No registered users and 211 guests
