irwin83r wrote:16bit wrote:ceramic coated, hydro formed inconel x is the only way to go!!!!
as far as exhaust goes.. what do you want?
performance?? up high? down low? mid range?
sound?? raspy and loud? low and rumbly? quiet as a mouse?
looks?? twin outlets? single? cannon shot gun style? cannon straight out center?
if i were you and i had the time and skills and wanted something totaly left field and different build a twin pipe system. so two 2-1 extractors into two 2" pipes going through high flow cats a good reasonator (or two hot dogs) and two rear mufflers. dont put a cross over pipe in and later get some lumpy cams fitted.. should sound like a boat at idle
nice, dis jointed and lumpy
SO I am looking at getting an exhaust made up for mine. Just bought a set of extrators on eBay 2" outlet. I am also looking at getting a high flow cat (which one??). But as for the rest of the exhaust, what should I do? I had one shop saying "i would run a 2.25 inch mandrel exhaust with resonatorand a step down muffler on the rear 2 inch (speeds up gas flow as gas temp cool down) all in mild steel....and dress it up with a stainless tip." The cost of which would be $500
Basically what I want out of it is just a bit of noise. Did my first track day yesterday, and one of my problems was not being able to hear the car!!! It really pissed me off. So I want to be able to hear it, so it has to be fairly loud, but I also want a bit of performance in the low to mid range. Not worried at all about looks or nothing.
Has anyone got a really good setup for road/race that is loud, but not busting your ears around town loud?
Also, is there any benefit to removing the muffler on a NA car?
