Removing Burr Walnut-effect-plastic trim
BigDamo
Postby BigDamo » Sat May 09, 2009 6:03 pm
Hi Folks
I've just been to look at an NB today that I'm quite keen on, but it did have a wood effect centre console and vent rings that weren't really to my taste.
I was just wonder if anyone knows how hard it is to remove these? Are they just stick on veneers, like the ones you see on flee bay, that can be pulled off or would they need to be replaced with regular black ones?
Would be good to hear is anyone else has done this.
Postby Hammer » Sat May 09, 2009 6:43 pm
There are two types of these type of trims. There's the stick-on style you mentioned, where it simply sticks on-top of an existing trim using a very thin double sided tape...
or
...there's the other (more expensive) kind, where it actually replaces the OEM trim. You need to closely look at the trim itself to figure it out. It should be easy to spot.
In my NB8B the brushed aluminium vent rings that I have are simply an alloy stick-ons. But the ones in my NA8 looks like they replaced the OEM black plastic trim.
Postby hks_kansei » Sat May 09, 2009 11:18 pm
most of the walnut/timber trims in cars is just a print over plain plastic, you should just be able to either strip/sand it and paint over as you would any other plastic.
or you could just buy normal trims off someone.
either way, little bits of walnut trim wouldnt be a dealbreaker if the rest of the car's in good condition.
tuned_to_fly
Postby tuned_to_fly » Sat May 09, 2009 11:49 pm
The centre console piece in the original black can be purchased from Mazda for roughly $80 new and MX5 Parts UK have brand new eyeball vents for 25 pound each. So absolute worst case scenario would be $300 to get it back to standard if you simply replaced the parts with new. Painting plastic dash trims can be a royal pain so I'd personally be happy to avoid the hassle and spend the cash :mrgreen:
Postby bruce » Sun May 10, 2009 12:04 am
You and a hair dryer will get them suckers off.
Tezzax5
Postby Tezzax5 » Sun May 10, 2009 8:10 am
Hammer wrote:There are two types of these type of trims. There's the stick-on style you mentioned, where it simply sticks on-top of an existing trim using a very thin double sided tape...
or
Hi Hammer :oops: the aluminium rings (stick on) in your clubbie were part of a group buy (Boags) way back when i owned it unless you had changed them. T
Postby Mr Morlock » Sun May 10, 2009 4:22 pm
The effect is likely to be a stick on trim. Suggest living with it for a while before jumping in-ones I have seen in wood effect look very good but tastes differ.
Postby Hammer » Sun May 10, 2009 5:46 pm
or
No, I haven't The trim is as it was when you owned them. They're very good quality, nicely shaped and thickish. Much better than what Mazda used on my SP - even though on my SP where also real aluminium trims (and not vinyl look-a-like).
BigDamo
Postby BigDamo » Sat May 16, 2009 7:10 pm
Thanks for the advise folks
I've ended up going of that car so I'll probably leave it and see if it grows on me for a bit, if not I might get all hairdresser on it and see if comes off. If it all goes wrong I guess I can replace them as mentioned.
Damo
Users browsing this forum: No registered users and 234 guests
