- 16bit
Renesis NC Track Car - In the Build - Updated 8 May 2009
jeff is the man - have you seen is throttle body setup he build for the 2.3 duratech. farkin amazing he improved on cosworths design.
I assume those to hex head bolts are a direct fit for the OEM calliper bracket, they just seem small compared to the load they must secure. Perhaps they just look small in comparison to that monster calliper.
- orx626
- Vehicle: NC - Rotary
saboteur wrote:Amazing work Danny! If you don't mind me asking; who tunes your rotaries?
Hi Tim, happy to tell....back in the day my carby fed rotaries were tuned by Peter Nankervis (Sandgate Dyno-->Mercury Motorsports-->Redcliffe Dyno now I think). The RX-8 and 626 don't require tuning...well the RX-8 doesn't at this point in time anyway . The Renesis NC will be tuned by Phil Laird (Graphic Skills Racing).
- orx626
16bit wrote:jeff is the man - have you seen is throttle body setup he build for the 2.3 duratech. farkin amazing he improved on cosworths design.
He has some very high quality products! If anyone here is into Duratecs he's the man to see about performance bits and pieces. Eurospeed Motorsport - ph: (07) 3865 5266
- orx626
Okibi wrote:I assume those to hex head bolts are a direct fit for the OEM calliper bracket, they just seem small compared to the load they must secure. Perhaps they just look small in comparison to that monster calliper.
Yes, yes and yes, Dave.
The bolts are all M12 x 1.75 Socket Head Cap Screws in 12.9 Grade (Hi-Tensile).
- orx626
Well I trial fitted the front brake assembly today....this is how it went.
Bare upright and hub.
Caliper bracket fitted.
Rotor fitted.
...caliper fitted .
The last test was to see whether the track rims (Enkei RPF in 18 x 8.5) would clear the brake assembly.
I couldn't have been happier with the result as there is plenty of clearance both radially and laterally....another box ticked. The caliper brackets will be hard anodised before the car hits the track.
For the rest of the day I continued paring out the wiring loom. It's slow getting smaller.
Rotor fitted.
...caliper fitted .
Renesis NC Track Car - In the Build - Updated 9 May 2009
In awe ... almost worth getting an NC just to buy Danny's "Big brake kit".
- zoomzoom
- Vehicle: NA6 - Turbo
Geez that brake assembly looks heavy!!!
It's going to need some work on the rears now to maintain that 50:50 weight distribution.
- orx626
zoomzoom wrote:Geez that brake assembly looks heavy!!!
I know . I should get Misha to knock up a rear bar for me hey Tim
Top work Danny.
Almost looks like you are trying to show up your colleague who does brake kits on the side...
Will the stock MC displace enough to move those callipers without a metre of pedal travel, or do you have a cunning plan for that too?
Show us the new main hoop!
M
M
- orx626
Mokesta wrote:Will the stock MC displace enough to move those callipers without a metre of pedal travel, or do you have a cunning plan for that too?M
If you get a chance, do some quick calcs on the sensitivity of master cylinder bore to brake caliper piston size and you will see where I'm going/gone . It's not what you would expect...well it wasn't until I ran some numbers. Pedal travel is sensitive to areas other than piston area ratio, and I'm not talking about the pedal lever ratio either. Let me know what you think.
- rwf
- Vehicle: NB Roadster
that looks great danny
Great work again
How's the roll cage coming along
Great work again
- orx626
Not much progress to report . Although I did pick up the Motec M800 from Phil Laird last weekend.
The car got a bit of a wash when I was in Japan. It's back on the RX-8 wheels for the time being.
- Old Dude
Renesis NC Track Car - In the Build - Updated 30 May 2009
Thats excellent Danny.
People in general don't appreciate how much work goes into a project like this, You should be really proud of what you have achieved.
I bet you can't wait to get it on the track
Regards
Old Dude
PS. my roll bar looks great
Regards
Old Dude
MX 5 2001 Grace Green
NB8B
NB8B
- orx626
Old Dude wrote:Thats excellent Danny.
Thanks Dale. Yes I'm very much looking forward to getting it on the track. I just have a few other priorities at present.
Old Dude wrote:PS. my roll bar looks great
Excellent!!! I wanna see piccies!
Users browsing this forum: No registered users and 29 guests
