Matty wrote:Looks good. Re the lap belt, is it not possible to feed the seatbelt through the side cutouts?
it is but as you can see the rails hold the buckle so the belt still needs to go over the edge of the seat to clip in
Alex wrote:ok now for some pictures of the modified rails
stock on top, modded down bottom
Starting with seats, is it generally acceptable to bolt in aftermarket seats so long as they are mounted on the OE (original equipment) seat rails?
Seating modifications generally affect compliance to two (2) rules: ‘ADR 3 Seat Anchorages’ and ‘ADR 22 Head Restraints’. ADR 3 covers the structural integrity of the seat base when it is secured to the original anchor points in the floor pan provided by the vehicle manufacturer. Where non-original anchor points are to be used, then advice from an Engineering Signatory is recommended prior to installation.
And converting from seat belts to racing harnesses? What then?
Any replacement seat belts must comply with ‘ADR 4 Seat Belts’ and must selfretract if the vehicle was originally fitted with retractable seat belts. Any fourpoint harnesses are generally not accepted in most vehicles manufactured to comply with ADR 4 and self-retracting inertia seat belts. Also, the relocation of seat belt anchor points is not recommended unless additional seat belts are retro fitted to early-model vehicles. In cases advice from an Engineering Signatory is recommended prior to installation.
