kaaz lsd - anyone got one
- 16bit
- orx626
- Vehicle: NC - Rotary
If you havent bought the kaaz yet, there's a cusco thats only at $500 so far ..
http://cgi.ebay.com.au/Cusco-Limited-Slip-Diff-for-MX5-MX-5-1-8L_W0QQitemZ170212036436QQihZ007QQcategoryZ6763QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
- wazman
I just bought a KAAZ 1.5 way for my NB ...... i'll get it put in at central diffs in morrabin.... once i get it out of the car
...... is there a thread that shows how to get the drive shafts out of the diff ???....Or can anyone tell me how?
... i'm used to the bolt on half shaft nissan style
ilovedrift.com
- corners
- Vehicle: ND - Supercharged
I bought shecks setup from his car and put it in mine and can backup that its really smooth and quiet but still binds time after time which is great!!
- Hellmun
- Vehicle: NB8B - Turbo
From memory on the NB it actually pulls out, the older NA's were a bolt arrangement with stub axles. It's been that long since I took the pumpkin out of my car to get the Tomei diff put in though....
- wazman
I got the diff out no worries.
I paid $1200 for my kaaz 1.5 way from "RMS" performance parts in melb, He had it in stock
I took it and the housing to "central diff's", who are now in fairview st in springvale, to get the back lash set.
Here's a handy link if you are about to pull out your diff and don't really know how.... clicky below
http://www.mx5ireland.com/members/srigley/writeup/Installing%20a%201800cc%20diff2.htm
ilovedrift.com
- irwin83r
looked into the tomie 20 clutch pack 2ways??
hi octaneracing syd can get em.. sure theres others
- wazman
Central Diff's (springvale,melb) charged me $250 to put the kaaz mech center in with new bearings and set the backlash.....i didn't bother with new seals because mine looked ok..... dropped it off and picked up the next day......
Got dizzy doing figure 8's to run it in...... good times
...... remember once you've done the figure 8's you have to change the oil.
so diff budget stands at.....$1530.....
Kaaz 1.5 way diff center $1200
center install/set backlash $250
extra can of Kaaz diff oil $80
Has dramatically changed the way the car drives! so much better from a performance point of view....... from a daily point of view its very tolerable.... only slight chatter when cold and turning tight under power...... I'm very happy and hanging back end out every chance i get !
ilovedrift.com
- 16bit
yeah they really help rear end grip. from about 20kph i can floor it in first in the wet and get NO wheelspin - thats with 160ish wkw!
- Damo
wazman wrote:Got dizzy doing figure 8's to run it in...... good times
Haha, that was good fun. For me, the most suitable place to do it was in a quiet carpark right behind a police station. I had no doubt that I'd get asked wtf I was doing, but I figured that I wasn't going to be doing anything illegal so, why not! I got summonsed over after about 20 minutes, but just explained that that was the safest place to do it and the officer agreed and let me get back to it.
NB8A (2000 Highlight Silver), KU36, Kaaz LSD, QFM A1RM, Mazda Competition engine/differential mounts, Town & Country cat-back.
- Alex
16bit wrote:yeah they really help rear end grip. from about 20kph i can floor it in first in the wet and get NO wheelspin - thats with 160ish wkw!
- 16bit
toyo r1r - they are amazing in the wet i have found.
- philz
- Wheel guru
R1R are excellent tyres better than RE001, they will be my next set.
