DIY centre console
DIY centre console
Been wanting to do this for awhile. When a mate gave me a lend of his nibbler I thought it was time to get started. Hope to build it for around $100 bucks...will show results as soon as I get the carpet overlocked.
NB SE, NA 1.8.
- Jeo
DIY centre console
One too many sets of image tags there Trader...
Looks interesting though, keep us posted.
- philz
- Wheel guru
DIY centre console
A cheaper alternative of getting the Nakamae look.
DIY centre console
Well I've just about finished it! Got to clean up how the carpet sits which means stitching velcro onto the carpet (tried gluing it but not successful). Found it to be a tricky job but at least it came in under budget - about $100 which is a lot cheaper than Nakamae. Re located the petrol opener in the boot.
NB SE, NA 1.8.
- philz
- Wheel guru
DIY centre console
Sweet good work!
This is a real one, and it looks just as good as it.
- Jeo
DIY centre console
Very nice. Well done!
- 16bit
DIY centre console
nice work - i would do this but find the space handy. real good job mate.
- sliq
DIY centre console
philz wrote:Sweet good work!
from recollection that was a D-technique? the nakamae has the window switches on console, not dash?
DIY centre console
that looks excellent!
what exactly have you used for the shape underneath the carpet?
if it was me, i'd rub the window switch and shifter surround back with P240 and P600 and leave it with a brushed sort of look to match your vent rings.
just a tip though. still looks great the way you've done it.
DIY centre console
Thanks for the tip IH8. I think I will try roughing up as the polished SS surround (from ebay) it too obvious. Currently, console is off the car as I'm looking for an electric clock to put either below the switches or between the gearstick ring and switches (anyone got one?). If I did it again I would put the switches somewhere else. Ive just got 1/2" foam under the carpet which is velcro taped along the sides but thinking of glueing it down when finally finished.
NB SE, NA 1.8.
DIY centre console
Sorry, I thought you meant the foam. A sheet of (offcut) 3mm aluminium.
NB SE, NA 1.8.
DIY centre console
Dissapointed with the look of the window switches so have added a clock to tie them in. I think it looks a lot better. I kept a pattern of the carpet and aluminium if anyone needs them.
[img][IMG]http://img195.imageshack.us/img195/1002/img07251p.jpg[/img][/img]
NB SE, NA 1.8.
Users browsing this forum: No registered users and 254 guests
