hey everybody. i noticed my handbrake light comes on when i drive quick around corners. it would stay on for a few seconds. it got worse, staying on longer and longer til the point where its been on for the last 2 days. came off tonight when i was driving home, before i eased the car literally around the next corner and its back on fastfreddygassit told me it might be some wires leaning on eachother round the corner, but im not sure where to start looking for this and which wires to look for. (i have an NA)
has anybody else come across this?
cheers
handbrake light stuck on.. solved!
- doogle
- SuperMazdaKart
handbrake light stuck on.. weird!
take out the centre console & have a look at the wiring for anything sus?
323s have the same sympton when the brake fluid in the reservoir got low enough that when cornering the sensor in there wouldn't be submerged & then lit up the brake icon in the dash. easily fixed by slightly overfilling the reservoir. might be the same thing on the MX-5, it's been a while since i've had a 5.
- Garry
What SMK said. Check the brake fluid level in the resevoir, if thats OK then start looking for dodgy wiring.
- Matty
Garry wrote:What SMK said. Check the brake fluid level in the resevoir, if thats OK then start looking for dodgy wiring.
And if it's low, start looking for a leak.
- Gazbo
It's certainly caused by low brake fluid level in the reservoir.
The brake warning light serves two purposes, an indication that the hand-brake is set on, and a warning that there is a fault in the brake system.
Daily: 2006 "C" Mazda3 SP23
Fun: 1993 NA6
Fun: 1993 NA6
- doogle
thanks for the replies. from memory i think my fluid was reaching the low level, i will have a look and if so top it up on the weekend!
doogle wrote:thanks for the replies. from memory i think my fluid was reaching the low level, i will have a look and if so top it up on the weekend!
If you notice your brake fluid is anything other than at the full mark always top it up.
If you've lost ANY fluid chances are there's a leak, top it up and keep a VERY close eye on it. If there's a leak you don't want to be driving around and run out of fluid.
Also check your rear calipers for leaks
- doogle
solved. it was the low level of brake fluid in the reservoir.
thanks to wun for helping me bleed the brakes and finding the leaky calliper too
https://www.mx5centre.com.au/index.php? ... cts_id=145
There is a rear caliper seal kit it seems kinda cheap. I have never fixed up a caliper before but if you trust me with your life I'm happy to have a go
anyone know where I can get a rear seal kit and a new hex adjuster for NB8B???
every ounce counts
They don't sell then here seperately at Mazda last time I checked a few years ago.
Also be weary of your piston and that it's not too badly pitted that you need a new one!
MX-5 parts in the UK have these.
Rear Caliper Seal Kit:
http://www.mx5parts.co.uk/product_info.php/products_id/306
Hex Adjustor:
http://www.mx5parts.co.uk/product_info.php/products_id/309
I also found these on E-Bay for a good price:
http://cgi.ebay.com/MX5-EUNOS-MIATA-REAR-BRAKE-CALIPERS-PAIR-BRAND-NEW_W0QQitemZ120378575460QQihZ002QQcategoryZ52640QQssPageNameZWD2VQQrdZ1QQcmdZViewItemQQ_trksidZp1638Q2em122
Hex Adjustor:
If your brake system doesn't have a leak, you shouldn't top up the fluid. As your brake pads wear, the pistons will come further out of the calipers and the fluid level will drop a little. When you put new pads in, you push the pistons back in and if you have just re-filled the system up, there will be more fluid than capacity There is a reason why I know this
Not RED
- fattima
Doogle I mentioned to you on Sunday I got my brake kit from the UK, this is the link
http://www.biggred.co.uk/
They are very easy to replace the seals in, compressed air helps to get the piston out. If your piston or bore is scored it may be cheaper to get a second hand caliper to repair.
