Brake pads
- philz
- Wheel guru
Brake pads
Alright time for some new pads.
What's good, what's bad?
NB8A- stock engine- daily driving.
- 16bit
Brake pads
qfm a1rm - $191 front and rear last time I purchased them. they seem great on rotors and work from cold just fine. and are also pretty good on track with temp rating of 0-780 degrees c. not much dust and make no noise at all. you can get them from gsl rally sport or try google qfm - queensland friction materials.
- d-mag
- Road Track Rally
- Vehicle: ND - Turbo
Brake pads
I've got a half used set of Bendix ultimates you can have for free phil.
Great street pad, I just don't need them as I've got track pads in there ATM.
MX5 Wanted. SE or NC (forced induction preferred )
- Boags
Brake pads
At the risk of sounding like Mr Morlock... OEM.
They don't overheat after 6 laps of a track. They don't create too much dust. They are good on rotors and work great from cold.
If they are even remotely similarly priced, I'd go OEM. People dismiss them automatically - they shouldn't.
Having said that; I got a quote for almost $500 for replacement OEM pads for my NB8B where race pads for the NA8 are $310... Bugger.
- fattima
Brake pads
I'm running TRW pads at the moment, after bedding in (get them very hot) they are a really good pad from cold. ABS shops sell them, the last set were under $100 for the front (NA6). I drive on the street and track with these pads.
- Boags
Brake pads
I had TWR Lucas pads on my NA6 and found that after 6 laps they were rooooooooted.
They stayed rooted after the track day too, for about a week (300kms).
YMMV.
YMMV.
- fattima
Brake pads
I've had no issues at all with them. I did get them VERY hot when bedding them in, mate who took out the Winton championship runs them also. Could be they have changed compounds?
- Boags
Brake pads
I bought mine in Jan 2006; so it's quite possible they've improved since. I really found them lacking a few times though.
- 16bit
Brake pads
as boags said the akebono oem pads are quite good from all reports. they are a ceramic based pad i think, similar to the carbotech pads from the states. if you do go the oem route make sure to specify actual oem not factory approved.
- philz
- Wheel guru
Brake pads
d-mag wrote:I've got a half used set of Bendix ultimates you can have for free phil.
Cheers Daz, I might take up your offer, I'll give you a pm soon.
But I'm really looking at new/full pads, just so that I don't have to change them again, so soon, but it's free
Thanks for the suggestions guys.
I don't mind brake dust, as long as it delivers the stopping power.
- Tedsmx5
- Vehicle: NA8 - Supercharged
Brake pads
Philz,
Good move, ultimates are dusty but "the best pad I have used in my life" and being free if you don't like them, ask for a refund .
Ted
Ted
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
- Tedsmx5
Brake pads
Philz,
Ted
Ted
- Garry
Brake pads
What he said. The "Mazda approved" ones are pov spec Bendix pads in a Mazda box and best to be avoided.
- philz
- Wheel guru
Brake pads
To be honest I have no idea when the brake pads were changed.
But the front are "firepower" and I'm not exactly sure if they are good, probably Bendix equivalant.
The rear haven't been changed I do not think, and I could be stock Akebono? Does anyone know what stock mx5 akebono pads look like do they have any markings/logos/numbers?
- Garry
Brake pads
The NB8B ones have a light blue coloured backing plate.
Users browsing this forum: No registered users and 112 guests
