need some info on the lil bits and pieces :)
travyMX5
Postby travyMX5 » Wed Apr 22, 2009 11:08 pm
just wondering if anyone can tell me all the little bits and pieces needed for a turbo conversion on an nb8a. By little stuff i mean vac line, oil and water line for the turbo, various fittings both at the turbo, block and thermostat etc??.... can anyone tell me sizes, thickness and lengths etc??
any help would be great. im doing an se turbo on nb8a motor if that helps??
thanx all :)
NMX516
Postby NMX516 » Sat Apr 25, 2009 1:37 pm
Mate if you're doing a custom install, then you'll just have to sit down and nut it out for your own circumstances. You'll probably have to play it by ear to some extent as you do the install. There is no simple answer except for the obvious larger parts like oil and water lines, intercooler and piping, hoses and clamps to suit those etc etc. You could go through parts lists from various turbo kit suppliers for a start. Begi kits are pretty comprehensive...
All this is part of the fun! :D
Postby bruce » Fri May 01, 2009 11:46 am
You are basically asking for someone to give you a step-by-step guide on how to do your install and list all the parts needed!
Alex
Postby Alex » Fri May 01, 2009 7:03 pm
take a look at the instructions for the AVO kits, might have some hints
Clicky
