AZNTieN wrote:hks_kansei wrote:wun911 wrote:Thats not a bad idea I know NB8B can dead lock a boot when you lock the boot with your key.
NB8A can as well.
did you have to do any mods to the lock?
i remember reading somewhere that you had to mod the lock
No mods required, in the US they need some though, but it's quite easy, something about filing/removing a tab on the lock mechanism. To dead lock it you just turn the key in the opposite direction to unlocking until you hear it click.
silvermiata wrote:only problem killing the power all together is your radio stations will never be stored after killing the battery which is pretty annoying..
Normally if your doing it for security you have the main power cut off by the switch then you have a secondary line still connected with a low amperage fuse which allows things like the radio to keep it's stations, this way you don't lose them but if anyone starts it up without connecting the main then the fuse will blow as soon as they try and get ignition killing all electronics
