Just installing turbo with integrated wastegate on NA6 with IC, big injectors / extra fuel pump and Megasquirt / EBC / Wideband O2 sensor / IAT ie. running no AFM / new 2.5 exhaust. For a track day / weekend warrior vehicle. No A/C anymore.
1. Is the idle intake hose best to be plumbed:
a) back into the intake pre turbo, post filter / pod
b) to just have a small filter on it so independent (easiest by far)
c) to be taking boosted/cooled air post IC / pre throttle body?
and why?
2. Also - any strong recommendations for gauges setup? I have a panel where the radio normally sits and will prob put water temp and oil pressure there so I can check if the ECU shows me signs of reaching set levels of protection.
Should be tuned and ready for some "higher load testing" by QLD MX5 Club trackday at Lakeside.
Thx all
Peter
