Anyone got instructions on how to remove the front bumper from my NA?
Juffa wrote:If you really want to remove the nose, try the following (based on a 1991 NA)
Remove plastic inner gauards under wheel arches, as this will give you acess to a number of screws/nuts holding the nose to the car body.
Remove plastic under engine tray, it is attached to the nose and taking it out will give you more room
Along the top edge of the nose, infront of the radiator there is a number of 10mm bolts holding the nose to the body. These need to removed as well.
I have probably forgotten something, but that should get you 95% of the way there.
Fatty wrote:mine is an NA but they shold be pretty much the same, i'd think. as per what juffa said, there are bolts all along the top edge of the radiator. after i took the plastic undertray off, and the plastic \"mouth\", i undid these bolts then just pulled on the nose gently until i found where it was sticking. remove that bolt (or screw) , pull gently again until i find the next bolt that needs undoing. it was pretty easy.
